Vacuum Problem
Old Mar 12, 2011 | 11:53 AM
stdyhand's Avatar
stdyhand
Default Vacuum Problem
After getting my vacuum gauge hooked up, I realized I have no vacuum showing. First off I don't even know if I put the vacuum hose in the right location. I put it between the PCV valve and manifold. Is this a problem?
There are two ports coming off both sides of the intake/TB, one on the front side of the car and one on the back and both are plugged. It was like this when I got it. Unplugging them doesn't effect how the engine runs.
With the gauge hose installed between the PCV and intake I can unplug from the PCV and there is no vacuum, but if I unplug from the intake and leave the hose on the PCV valve the gauge shows about 6-8 hg.
This leads me to believe there is vacuum between the PCV and intake but not enough for the gauge to show.
From what I've read elsewhere I am lead to believe the proper vacuum specs should be about 56+ hg.
I haven't heard any vacuum leaks plus the last owner has removed a canister or two of the vacuum system so I don't know what it should read at now anyhow.
Anyone else using a vacuum gauge? What is your normal idle vacuum and where do you have your hose installed?
Ipaman
Sep 22, 2015 07:01 AM
stangin1996gt
Sep 21, 2015 11:01 AM
SteelerNation82
Sep 16, 2015 07:11 AM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
