how much hp?
Old Apr 24, 2011 | 09:35 AM
jst98gtmustang's Avatar
jst98gtmustang
Default how much hp?
well i have always own a 4.6 an was thinking of buy this 93 gt.what kinda of horse power will i see an 1/4 1/8th times with theses parts.
Eldebrock Performer2 Upper & Lower intakes
E303 cam
TCI streetfighter 3000 stall
BBK cold air
BBK70mm throttle body& EGR delete
BBK headers
BBK X pipe
B&M rachet shifter
New Lifters
New Pushrods
New 1.6 Rokers
Ford 8.5 wires
MSD cap and coil
Underdrive pulleys with smog and a/c delete
Old Apr 24, 2011 | 09:48 AM
nightmare90gt's Avatar
nightmare90gt
the rpm 2 is to much intake for your set up, unless you got a good set of heads it will hurt you, your best bet is to get a good h/c/i combo
also you can make your own egr sim so the check engine light doesnt come on
Old Apr 24, 2011 | 09:57 AM
jst98gtmustang
Ah ok..i'm not sure if it has heads or not this is what the guy told me it had..
Old Apr 25, 2011 | 01:17 PM
nitrous_bob's Avatar
nitrous_bob
it'll go 14's cuz it's an AOD and stock heads.
get a 5 speed car, aod's are too easy to break and about a full second slower than a t5 car.
fyi my all stock '89 notch went 13.20's with exhaust and 4.10's
Old Apr 25, 2011 | 05:48 PM
88 orangepeel notch's Avatar
88 orangepeel notch
Sounds kind of like the same setup I have. Except previous owner get some head work the stock heads. Dynoed 275hp,
305 trq. at wheels. That was a baseline run, no tuning. Ran a best of 13.5 at 109 . It's a real eye burner at idle.
