good setup
Old May 25, 2011 | 04:55 PM
killakane1427's Avatar
killakane1427
Default good setup
iam buying a e303 cam is that good cam for my setup. 1985 mustang 5.0 4 barrel holley carburetor edlebrock intake bbk headers flowmaster turndowns. and going to put a t5 in and take out my c4. is it hard to change out tranny car was originally a 5 spd
Old May 25, 2011 | 06:21 PM
uedlose's Avatar
uedlose
Not really it is just nuts and bolts.
Old May 26, 2011 | 12:21 AM
killakane1427
so what about the cam
Old May 26, 2011 | 04:35 AM
AdderMk2's Avatar
AdderMk2
Banned
you can do SOOO much better that that turd of a cam.
Old May 26, 2011 | 10:40 PM
killakane1427
adder what should i run with my setup. this is my first stang still learning
Old May 26, 2011 | 10:47 PM
Venomantidote95's Avatar
Venomantidote95
If you have stock heads and those mods you dont need to stress too much on the cam if its cheap get it lol!
like 50$ cheap not 200 from summit! If your option is the 200$ cam get a tfs stage 1.
Old May 26, 2011 | 11:05 PM
killakane1427
its $115. if i get tfs do i need heads right now or the stage 1 will work with what i got
Old May 26, 2011 | 11:12 PM
Venomantidote95
If you have stock heads they only flow upto .500 unless worked but not really worth the time! and yes if you get the proper springs, and when you upgrade heads stay moderate unless you are gonna upgrade the cam again. If you get a head that flows around .550 then you could opt for a 1.7 rocker ratio unless you just want to use a different cam! the rockers would put you to a .530/.541 from the .499/.510 with the 1.6`s.
Old May 26, 2011 | 11:31 PM
killakane1427
so just go with the e303 for now with no other upgrades it will go right in.
Old May 26, 2011 | 11:39 PM
Venomantidote95
yes if your stock springs arent wornout! i would say no if you were efi for induction reasons but you dont have them with a carb.
