Rad selection help.
Old Jun 5, 2011 | 06:17 PM
Ze2222's Avatar
Ze2222
Default Rad selection help.
Hi guys need some advice again. I'm about to purchase a rad for my 408w powered foxbody.
I'm running a c4. Now should i get a rad that has a trans cooler with it as well?
I already have a seperate trans cooler i'm using as well.
Car is pure track use only. Reason for asking is do i want the engine coolant temp to be heating the trans fluid?
Wouldn't you think it'd stay cooler with just a single cooler for the trans?I hope i'm making sense would like some opinions before i buy.
Old Jun 5, 2011 | 07:56 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
just run the external cooler you have and make sure airflow across it is good and what I recommend is run a deep sump pan on the tranny with cooler fins so it can pic airflow up across it from under the car, these two things together keep the c-4 nice and cool
Old Jun 6, 2011 | 07:25 AM
uedlose's Avatar
uedlose
track use only car if you get running rounds back to back the trans is gone to get hot trust me been there done that I even lost a pump busing and seal due to the heat before. That is also one of the major issues with a C4 they dont hold much fluid and getting the heat out of them can be tough. I have moved up to a trans cooler with a fan on it for our car that is one of the added things this year. So I have not got to try it.
Old Jun 6, 2011 | 07:29 AM
4rdnut's Avatar
4rdnut
I would run both the radiator cooler and the largest aftermarket cooler in series, this way the trans fluid warms up faster to operating temperature but the overall temperature of the fluid will be cooler because the radiator cooler drops the trans temp, then it goes through the aftermarket cooler and cools down further, two is always better than one. Buy a radiator with the automatic cooler fittings, you can always keep the cooler openings plugged and use the radiator for a manual transmission, this way you have a dual purpose radiator, two is better than one, you dig?
Old Jun 7, 2011 | 03:23 AM
Ze2222's Avatar
Ze2222
thx for all the suggestion guys. really appreciate it.
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
NYstang
Sep 30, 2015 09:56 PM
mustangheaven
Sep 29, 2015 11:00 AM
