5.0 conversion
Adder he has already been behind the dash!
Go back thru and make sure every connector is fully connected!
SN cars arent like foxes, you dont have the hoopla harness issues!
You can go from 5 speed to auto and just swap the ecm!
did I mention that the muatang is a 98, i had a 5.0 sitting in my garage and i was told that all i had to do was chang the engine harness and ecm ,i did that and it wouldnt start so a ford mach told me that becauase of the pats module i need to change the dash harness so i did that, also he said i need to change the engine compartment fuse block and harness so i did that and now my horn works forever i cant start the car withe the key and it does run but it surgee when i hit the gas it trys to reach rpm but struggles and the check engine lite comes on someone please guide me in a better direction.
