347 Would you Rather?
Okay i have been debating on ways to upgrade my 347 Stroker, and have posted a couple threads about it.. My goal is to keep my 347 Stroker at a max rpm range of 6500. Longetivity on the block is the overall goal on this. So my Current Set-up is this (I already know im gonna catch Flak about it)... I have e303 Cam, GT40-P Heads(highly ported/Polished) and GT40 intake port matched to the heads. 24# injectors and 3.73 rearend.
Now i have an opportunity to buy a Novi 1000 kit complete with 42# injectors for about 1600 dollars...Or AFR 205 with a SuperVictor Intake for about 1900 dollars.
I do want to stay in the 6500 rpm range, so what would u imagine is my ideal setup? Im still aiming for at least 11's in the 1/4 mile...
Maybe i should hold out till i find the setup im looking for? If so, what would that setup be?
How many reocurring post on these same garbage setups are we going to have?
Use your current setup with the highly ported p`s and setout for some 13`s!
Use what you have on a 302 and get the Novi kit and have some fun! That would be much more practical!
Im willing to spend money.. Just trying to find the most effective and efficient way to go about it. All the setups i see arent built for the low end, but thats where i want to live.. So 302 parts seem to keep me there, and maybe the novi would make up for the fact that im choking my block?
MK2 you did give me very good advice on how to build my 347, however the builds u recommended were high in the rpm range. MJR your build is the route i think im going. I was just curious of what other combinations r out there. Only doing this once, so id like to get the most information as possible.
How so? I never once recommended a TLSR build... FWIW, even if you did an exact copy of my build, you would be shifting at 6400.... which is under the RPM range you have requested.
