do i need a diff girdle
Old Aug 13, 2011 | 07:26 PM
raftdaddy's Avatar
raftdaddy
Default do i need a diff girdle
i just re did all my rear end with 4.10's hardened axles,spherical bushings,upr control arms. i had the axel sandblasted and painted and had them weld the tubes in as well. i have an auto with stock stall but am spinning the tires pretty easy now especially with the n20 on. i am going the strip in three weeks and am wondering if a girdle would be a good idea. i am looking at the scott drake or tfs or ta girdles. i did dyno at 312 rwhp (mustang dyno) but had a flow issue so i should have 60 more hp with the n20 shot so i'm guessing on regular dyno i should be close to 400 whp. allso don't use a fluid 90 on n20 that's were i lost my flow.
Old Aug 13, 2011 | 08:57 PM
tinman's Avatar
tinman
I don't think a rear axle girdle is bad idea at all. Remember, you'll get what you pay for so shop with that in mind.....
Old Aug 13, 2011 | 09:09 PM
raftdaddy's Avatar
raftdaddy
i looked and most seem to be around the same price except the upr which is double so basicaly i'm shopping around by looks unless i'm told otherwise. but do you think i need it?? i'll do one trip to the strip this year as i'm about 600 miles from the nearest strip and we have long winters so i would like to put it off till this winter when i do my k member. even if thier is the slightest chance i could prevent a failure i'll get one. the suspension or front end is the last place i want a failure,let alone dumping any oil at the start line!!!
Old Aug 13, 2011 | 10:42 PM
Boss_Hotrod's Avatar
Boss_Hotrod
Ive got a mac one on my car. Dont know if it helps it or not but I mainly did it for the fill and drain holes. Plus they look cool. I dont drag race my car just beat the crap out of it on the street.
Old Aug 13, 2011 | 11:38 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
they just look cool and make draining axle fluid easy
Old Aug 14, 2011 | 12:57 AM
5.0kid's Avatar
5.0kid
they are a good idea if you got spare money to spend, but with that power a proper built rear end i dont think you'll have to worry about blowing it out unless your 60' ing in the 1.5's or better
Old Aug 14, 2011 | 04:27 PM
raftdaddy's Avatar
raftdaddy
no,1.5's are not going to happen till i do do my stall and tranny. thanx for the input guys i'll wait till this winter and do it then.and i'll try to post video of the track and hopefully i'll be dipping into the 11's. i've set a second a year goal and so far so so good.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
Cavedawg
Sep 17, 2015 09:51 AM
Urambo Tauro
Sep 7, 2015 12:47 PM
Sep 1, 2015 08:16 PM
