Rear End Work
Old Mar 2, 2012 | 11:17 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Originally Posted by bluebeastsrt
I'm not going to flame you but I do disagree. What power level are you at? And why wouldn't you replace the axles when you have the rear apart. A new ford trac lok diff. and new 31 spline axles can be had for $500. You'll have piece of mind even if you want to build a 10 second car down the road.
I run HD yukon 4 lug 28 spline axles and slicks, broke motors, tranny but not the axles, not saying 31 isn't a good idea just had good luck with what I have so far oh and the car runs mid 10's @128
Old Mar 2, 2012 | 11:20 AM
bluebeastsrt's Avatar
bluebeastsrt
I had the same good luck with my SRT-4. But when it comes time to swap out the stock gears for something a little more agressive. I'll do everything. I just like the idea of doing something once and forgetting about it.
Old Mar 2, 2012 | 11:27 AM
mjr46's Avatar
mjr46
I've seen 31's break too , so in my book there is no ever "doing something once and forgetting about it" but if it gives you piece of mind that's all that matters, for me I haven't worried about the axles on mine, they have taken 5 + years of abuse. But sooner or later I'm sure something else will break on it
Old Mar 2, 2012 | 12:34 PM
bluebeastsrt
Drive it hard it'll break!! The neon would spit out a clutchs every couple of years but never broke a stoke axle. I don't think I'll have enough money to worry about the rear this year. Looks like the top end and spray will happen though.
Old Mar 2, 2012 | 02:50 PM
im_stuck_in_iraq's Avatar
im_stuck_in_iraq
Cool
Originally Posted by mustangGT86_05
If you're simply swapping out the carrier it isn't too bad, you will need to reshim it though. I can't remember exact process but you can do it ok in a garage on the floor.
"reshim" ???
Old Mar 2, 2012 | 03:01 PM
Tony71502's Avatar
Tony71502
Take it to a shop.
Old Mar 2, 2012 | 03:31 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
When you pull it apart there are shims on both sides of the carrier when you remove the 2 caps. Just keep track of which ones are on which side of the carrier.
Old Mar 3, 2012 | 09:09 AM
im_stuck_in_iraq
Thumbs down
Originally Posted by Tony71502
Take it to a shop.
i have people that know what there doing around me im just trying to figure it out myself. Isn't that what this is all about? Thanks for the positive reinforcement ahole
Old Mar 3, 2012 | 09:10 AM
im_stuck_in_iraq
Talking
Now thats an answer.. thank you kind sir
Old Mar 3, 2012 | 10:11 AM
mjr46's Avatar
mjr46
He didn't call you any names so don't start with such , it'll only leave you with the short stick in the end, thank you and carry on
