How good is my setup??
I have a stock crank, tmd rods, 306 with 11:1, hyperknetic pistons, anderson ford motorsport n-111 cam, victor jr heads with castings cleaned up and crane gold rockers, prefessional products typhoon intake, #42 injectors, msd pro billet distributer
^^^ what he said but but I could be very wrong but with the rpm's you're gonna have to spin the motor I feel like the intake mani is gonna hold you back and choke the motor up top unless it's a ported typhoon intake.
did you do ANY port work ? i think a little goes a long way for some things
IMO, you should always port match the lower to the heads, and the heads will respond really well to porting the exhaust to a gasket match, also a good multi angle valve job
your probably looking at only $300-$500 max in labor
there are other things...like if your heads have a thermactor bump, milling them to bump compression, smoothing the intakes, or bowl work
but the few things i said i feel are critical for good velocity and smooth airflow
mungodrums
10-07-2015 04:01 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
