Clutch Cable replacement
Old 04-26-2012, 01:05 PM
lkwd_90notch
lkwd_90notch's Avatar
Default Clutch Cable replacement
I just replaced my clutch cable and for some reason the clutch is way easier to push in than before. I replaced it with the same cable from Ford Racing.
I'm wondering if I did anything wrong or if maybe I could damage something. It shifts gears fine and everything.
lkwd_90notch is offline
Old 04-26-2012, 01:26 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
maybe it was that your old cable was catching/binding in the sheath ...ever think of that?? why did you replace it to begin with?? stiff pedal??
mjr46 is offline
Old 04-26-2012, 01:45 PM
mustangGT86_05
mustangGT86_05's Avatar
^ truth, if your clutch fully engages and disengages plus you checked all your connections to make sure they're secure, how would something be wrong?
mustangGT86_05 is offline
Old 04-29-2012, 12:37 PM
Foureyed
Foureyed's Avatar
Maybe your old cable just needed a little lube.
Foureyed is offline
5.0muscle
01-11-2016 01:17 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Clutch Cable replacement
