Smog Test Today, Last Minute Checklist?
Time to attempt the dreaded california smog today.. again. Are there any preparations i can make before the test?
The car idles at 750 rpm. Timing is set to 14*. Should i bring it back to factory (10*) or does that even matter? It's on 91octane as always and i used a bottle of that crc "guaranteed to pass" stuff in the last tank. Not sure if it works but i guess i'll see. Is there anything else i should do before the test today? |
If the lines are long, shut it off. Don't idle it in line for long periods to run the AC as it will likely load up. About a minute before they stick it, hold the rpms about 1200-1300 so the cats are nice & hot as they'll work most efficiently when up to temp. Good luck :-)
Being an '86 it isnt exempt or is it not old enough for that?
Originally Posted by PNYXPRESS
(Post 7973528)
And thanks. Hopefully the cats'll be warmed up enough when i get there. Just took the timing down a notch between 10* & 12* Gonna go test now. Wish me luck! |
