Which injectors
Old Oct 4, 2012 | 05:07 AM
adrnlnjnky700's Avatar
adrnlnjnky700
Default Which injectors
just ordered the vortech s-trim kit. With whats currently in my sig plus the supercharger which injectors should i be running? i have a set of 30lbs in there right now, max power on the dyno were at 65%duty. Also have AL 3924 plugs, are these still going to be optimal, understand i will have to gap them a little smaller. thanks
Old Oct 4, 2012 | 05:17 AM
dawson1112's Avatar
dawson1112
It is most likly that youll need to go to a larger set of injectors as supercharged engines require a larger injector at a lower HP than that of a naturaly aspirated engine. I came across this web site a while ago that has a good formula for calculation of injector size.
http://mustangpartstech.com/FuelInjectorMath.html
Old Oct 4, 2012 | 06:51 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
42's at least
Old Oct 4, 2012 | 02:45 PM
adrnlnjnky700
ok, thanks
Old Oct 4, 2012 | 04:01 PM
5.0kid's Avatar
5.0kid
like mjr said 42's at least when i had my s trim i was at 93% duty cycle with my 42s at the end i wish i had 60s
Old Oct 4, 2012 | 04:08 PM
adrnlnjnky700
how much power were you making at 93%.
Old Oct 4, 2012 | 07:38 PM
mjr46's Avatar
mjr46
iirc his car ran solid 10's
Old Oct 5, 2012 | 07:26 AM
01MGGT's Avatar
01MGGT
When I has a v1 vortech on my 01 GT with a 4.6 I was making 375 to the wheels with cams and 42lb injectors. That was at only 7 or 8 psi. Tuner said the injectors were almost maxed. So I would play it safe and get bigger than 42. Sure beats pulling the manifold again to get the rails off. Also just a tip when installing the new injectors, I had a HELL of a time getting them in niceley just putting my stock ones back in my 5.0 with new o rings. I found vasolene(sp?) made it WORLDS easier! Even motor oil was a PITA for some reason.
Old Oct 5, 2012 | 07:35 AM
adrnlnjnky700
alright sounds good. i think im getting pretty good at replacing injectors and the vaseline trick def helped last time.
Old Oct 6, 2012 | 04:52 AM
5.0kid's Avatar
5.0kid
guestimated around 650 at the crank on a STOCK BLOCK AND INTERNALS WOOOT. figured 3205lbs race weight and it would run 10.47 at 130 almost every time
