Help!
Old Oct 29, 2012 | 02:08 PM
Kash De La Cruz's Avatar
Kash De La Cruz
Default Help!
So im getting the 302 trickflow top end small block ford kit and replacing my headers with bbk shortys.. My only concerns are will i have to replace my transmission its stock... will it be able to handle it... and will i have to switch the gear ratio?
Old Oct 29, 2012 | 02:23 PM
bluebeastsrt's Avatar
bluebeastsrt
Your transmission will be fine. No you dont have to switch anything. If your looking for performance. you'll want to get better gears out back.
Old Oct 29, 2012 | 08:42 PM
capri debris's Avatar
capri debris
So you have a stock trans.... but is a T5 or an AOD?
Either way, I wouldn't expect it to last long.... I have the TF kit and it puts out considerably more power than a stock engine which puts out just under what a stock trans is rated at.
I went with a Super Comp C4 rated at 1000 hp... a little over kill for what the TF kit puts out, but then again, I also have 150 hp wet shot of nitrous.
