Super low idling
Something is really wrong with my idle/throttle response. It seems
Like my car is running lean. When my cars idle finally settles down, it's idling at 500-700 RPMS.. And it's causing horrible shaking of the car. Also sometimes when in 3rd gear just cruising it like bucks for a second or two.
Someone suggested I might have a vacuum leak, because at around 4,000-5,000 rpms you can hear whistle/hiss.
I don't know if a vacuum leak affects throttle and idle response? What could be causing my car to idle so badly low? And can a vacum leak cause bad idle or throttle response?
The intake set up is
BBK Cai, 75MM throttle body, Trickflow Elbow, and Comp Cams intake manifold. Stock MAf
Are you running this manifold? http://www.compperformancegroupstore...Category_Code=
That thing will kill all low end torque with those ultra short runners.
They work better with a turbo or supercharger.
How far open is the throttle blade at idle?
