I need some ideas on breather set ups. I don't really want to run the factory pcv setup. I'm going to vent both valve covers, but need ideas on whether to just run two breathers or run a catch can (need ideas for mounting catch can as well). Post some pics or ideas!
not to thread jack, but whats the benefit of running a catch can? Also I'm using the valve covers off of my 302 and only one side is plumbed for a filter.
Its all good. Catch cans keep the oil off of the valve covers and exhaust manifolds. The breather on the valve cover will start to drip since there is oil mist being vented out with the crankcase pressure. To me, a catch can is easier maintenance than trying to replace a pcv system. So you'll vent both valve covers to a catch can, which then has mesh on the inside to separate the oil and air. Then the air is vented to the atmosphere via a breather on top of the catch can.
I am just wanting to know how to go from the valve cover to the can
I use breathers on both my valve covers and I have NEVER seen any oil dripping out of them.
Been running it that way 3 years now..
This fall I plan to go to a vac-u-pan setup how ever.
