help
Old Jul 30, 2013 | 11:27 AM
rats8950's Avatar
rats8950
Default help
here we go new maf,plugs wires,cap rotor tb stock, egr,tps,.idle control,timimng base at 15,fuel pressure at 40,fuel reg works well with vaccum, no vac leaks, 1989 50,ho in a lx,auto,good oil pressure temp ok, will start, runs like its laboring missing and wond rev beyond 3 grand,wont stay running, at the end want to run it in the damn river any sugestions, cleared codes and put all new stuff on and now i have 23,32,11,98,66, all the stuff was replaced also checked timing makes to 0 deg all good no slop uggggggggggggggggggggggggggggggggggggg hate my stang
https://mustangforums.com/forum/imag...con_bricks.gif
Old Jul 30, 2013 | 02:54 PM
Tony71502's Avatar
Tony71502
Sounds like you didn't stab the distributor right. I would start there... it's free.
Old Jul 31, 2013 | 12:25 PM
rats8950's Avatar
rats8950
Default dist
tryed stabbing again its dead on fireing order good, today i replaced all vaccum lines, intake,injectors and rail fpr,new pcv, still runs on four cyl, checked plugs again 4 where black and 4 clean , they where rich burning no other contaminates,could the module and coil be going?
Old Jul 31, 2013 | 12:35 PM
dawson1112's Avatar
dawson1112
with all those codes , plus the code 98 ( hard fault present )
you have a short or a ground issue.
Old Jul 31, 2013 | 01:07 PM
88 orangepeel notch's Avatar
88 orangepeel notch
Salt and Pepper connections,
Old Aug 1, 2013 | 05:13 AM
rats8950's Avatar
rats8950
Default help
ok short or ground will check and reply thank you for the tips really thankfull.
Old Aug 3, 2013 | 07:40 PM
2011scgt's Avatar
2011scgt
did you check fuel pressure just at idle? plug out when you checked timing?
