OIL CONSUMPTION
Old 04-15-2015, 08:45 AM
BLK15GT
BLK15GT's Avatar
Default OIL CONSUMPTION
I bought my mustang back in the middle of january and have put 3000 miles on it so far. In that period it has used 1 qt of oil. Should I be concerned about this
BLK15GT is offline
Old 04-15-2015, 08:54 AM
jz78817
jz78817's Avatar
both my 2010 GT (4.6 liter) and my 2012 GT (5.0 liter) consumed one quart within the first 5,000 miles, and none thereafter. It's more or less normal for a brand new engine to use a little oil while everything is seating in. if it stays that way or gets worse, you'll probably want to have it looked at.
jz78817 is offline
Old 04-15-2015, 10:06 AM
jwog666
jwog666's Avatar
^^^^+1 the spec for allowable oil consumption is close to 1 qt per thousand miles if i remember correctly. i wouldnt worry about it the powertrain warranty is
good to 60k miles or 5 years. so monitor it and i bet you will see the consumption go away by your 3rd oil change
jwog666 is offline
Old 04-19-2015, 02:13 PM
topangler25
topangler25's Avatar
The spec is 1 quart for every 3000 miles. You are ok. The 5.0L uses some oil. You will lose most of it while coasting down in gear/engine braking. You should get an oil catch can and see how much goes through your PCV system back into the intake.
topangler25 is offline
Old 06-17-2015, 01:49 PM
cduballstars
cduballstars's Avatar
consumed 1 qt in 2500 miles in my 15'.
cduballstars is offline
Old 07-18-2015, 10:15 PM
JC500
JC500's Avatar
I just hit 1600 miles on mine and oil has not dropped a ounce. I drove it east to moderate first 1000 and last 600 been driving her hard and still not eating any also gas milage is good better then the first 1000
JC500 is offline
Old 07-25-2015, 06:49 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
That's not uncommon. But it's nice to run a catch can to keep that oil out of the intake manifold.
http://www.uprproducts.com/amp-musta...r-mini-11.html
UPRSharad is offline
Old 07-31-2015, 09:22 AM
squishbang
squishbang's Avatar
I added an oil separator/oil catch can a week or so after I bought my car. I've yet to check it. But I'm curious: What do I do with the oil in the can? pour it back in? Throw it away and add fresh oil instead? Use it with chicken bones and vodka in some type of voodoo ritual?
Just curious.
squishbang is offline
Old 07-31-2015, 09:36 AM
Moderator
JimC's Avatar
Just curious.
Throw it out, do not out it back in the engine. The oil in the catch can is contaminated.
JimC is offline
Old 07-31-2015, 10:13 AM
squishbang
squishbang's Avatar
thanks.
what type of oil does Ford put in there from the factory?
Quick Reply: OIL CONSUMPTION
