Sponsored by:
Sponsored by:
Android Auto
Old Oct 12, 2020 | 07:26 AM
ucinn's Avatar
ucinn
Default Android Auto
Got a quick question regarding using android auto. Just got a 2020 GT Premier Vert, When using AA, is there a way to get back to the audio screen to change music sources? My Kia had a physical button you could push, but couldn't find any way on this to get back to audio sources. I ended up unplugging my phone, changing the source, then plugging it back in. Thanks in advance for the help.
Old Oct 12, 2020 | 10:02 AM
proeagles's Avatar
proeagles
You should be able to hit the Ford Sync icon which would take you home, then audio, at least that's the way it is with CarPlay.
Old Oct 12, 2020 | 10:20 AM
JimC's Avatar
Super Moderator
Correct, you hit either the "sync" button on the screen or "exit" or "Ford exit" button to get back to the Ford screen. You have to hit the circle on the lower left first to get to that screen of additional apps.
Old Oct 12, 2020 | 12:24 PM
ucinn's Avatar
ucinn
Thank you for the help, I knew there had to be a way.
Old Oct 12, 2020 | 12:25 PM
ucinn's Avatar
ucinn
Thank you for the help. Knew there had to be a way, but couldn't figure it out. Going to take a little bit to get used to the Synch 3 coming from Kia's UVO system.
Old Feb 24, 2021 | 06:20 PM
ucinn's Avatar
ucinn
Anybody else having trouble with their Android Auto with the sync 3? Problem with two different phones and 3 different cables. It was working fine then all of a sudden within the last month, it's not connecting sometimes and Waze isn't working correctly. My phone works correctly with my wife's Kia Telluride so it's not a setting in my phone. I'm at a loss a to why it works differently in the two vehicles. With Waze in the mustang, my icon is gone, the map is zoomed in so far you only see about 100 feet of road, if you zoom out, it will zoom right back in when you start moving, It also sings the map around whenever you go past a side street. The speed limit and my speed is also missing. Anybody got any ideas? My Waze and sync 3(3.4) is updated
Old Feb 24, 2021 | 07:39 PM
JimC's Avatar
Super Moderator
That happened with my 2017. Now I start in Google maps and then switch to Waze and everything is back and working properly.It seems that if Waze is my startup something doesn't load properly.
Old Feb 24, 2021 | 07:57 PM
ucinn's Avatar
ucinn
I'll try that tomorrow and see if that does it. it's got to be something with Sync 3..it works perfectly every time in the wife's Kia. It was working fine in my mustang until about a month ago..very weird...thank you very much for the suggestion.
Old Mar 2, 2021 | 08:05 PM
ucinn's Avatar
ucinn
That seems to be the trick. That worked so thank you.
one eyed willy
South
Jan 9, 2009 03:02 PM
5.0kid
Sep 25, 2008 08:10 AM
BatMobile00
15
Aug 19, 2007 08:15 PM
ridedk4us
May 8, 2007 10:26 PM
canes44
Mar 23, 2006 11:07 PM
