5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Performance Tune
Old Dec 15, 2010 | 11:02 AM
daredevil95's Avatar
daredevil95
Default Performance Tune
Hi, I'm not sure when is the best time to install a computer tune. When adding a CAI & PCM tune.....is better to do this last? Should other performance mods be installed prior to a PCM tune....such as Headers & exhaust, 4.10 gears, not sure if tire size makes a difference, pullies and anything else I didn't think of. After reviewing different PCM tuners I noticed that these new style tuners could be application specific......doesn't matter for mild performance improvements? Any advice will be appreciated?
The last PCM tuner (hypertech) I bought was a few years ago for a Corvette. It made a difference, but all I could adjust was rev limit, tire size for speedo and gear ratio....the tunes were pre-programmed......do the new 5.0 programmers have these same features? Advice from a tuner veterans is appreciated. Thanks in advance.
Old Dec 15, 2010 | 11:13 AM
pdonket's Avatar
pdonket
If you buy from a company like Bama or Brenspeed, they'll offer you liftime updates to your custom tunes. That way you get more out of your tunes in the first place since they're honed in to your own car, and then as you add things, you can call them up and let them know and they can make alterations to your code and then you just upload the new ones onto your tuner and then onto the car.
Getting a tune early on is necessary when it comes to a bunch of the alterations that involve air flow changes or high performance changes.
Old Dec 15, 2010 | 12:49 PM
AMChrisRose's Avatar
AMChrisRose
Pretty much exactly what the last post said is true. You need a tune in order to run most modifications on 05+ Mustangs. Cold air intakes, long tube headers, etc. - they need to be properly dialed in inside the calibration. As for rev limits, tire sizes and axle ratios - we're going to take care of this stuff for you inside the custom tune so that the speedometer is correct. This is crucial more for automatic vehicles, to ensure they shift correctly. And we give you free tune updates for life, so that any future modifications are taken care of as well. If you want more info, I would call one of our Bama Custom tuners and speak to them. They can give you awesome technical info and go over the options with you. They're here in the building Monday-Friday 9AM-5:30PM EST. Give them a call at 888.226.9764 directly!
Old Dec 15, 2010 | 01:39 PM
daredevil95
Is there a tuner tool/software available so that we can do the adjustments ourselves? I know it's complicated...but, the fun is also in the learning. Not meaning to use this as a qualification....roughly 18 years ago or so... we had primitive software and would actually adjust the programs line by line and then convert into graphs and if we were happy....burn it on to a special blank chip and install back into the computer.....like a said primitive software...we used on Z28s and Vettes. It was a lot of fun, it seems complicated at first, but after some time playing around with it was very understandable, offers a lot of value as far as flexibility. I have no idea on what to research as far as vendors or if something like this is within a reasonable price. Any advice will be appreciated.
Old Dec 16, 2010 | 05:55 PM
daredevil95
Any info?....anybody??
Old Dec 16, 2010 | 08:03 PM
AMChrisRose
The software is either SCT or Diablosport. I know SCT is about 1500 for the single Mustang year package, or something like maybe $5000 for all Mustangs. This will give you VERY VERY basic access, and surely not enough to fully tune the vehicle. It will have basic fueling and timing parameters. So then from there, you can head down to Orlando and check out SCT's Basic and Advanced training courses. They're 1500/pc per person, and you'll be there for a few days - but it's definitely worth it. You'll learn basic and advanced PCM controls and functions. The nice thing about it is that the advanced class completion will unlock drive-by-wire and other functions that are necessary for tuning a Mustang (05+ especially).
Old Dec 16, 2010 | 08:23 PM
daredevil95
Nice....thanks....I'll look into it.
SCT Pro-Racer Advantage III Ford Tuning Software (Software Only)....found it....thanks!!
Old Dec 16, 2010 | 09:14 PM
daredevil95
Chris,
Hi, If I bought a SCT Bama tune from you guys and also bought the SCT Pro-Racer Advantage III software.....would I be able to unlock the Bama tunes and make modifications/alterations?
Old Dec 19, 2010 | 06:59 PM
CJStang50's Avatar
CJStang50
I definitely understand wanting to modify tunes. However, if you don't have a dyno, not a good idea. Trust the professionals. I recommend John Lund (of Lund Racing).
Old Dec 19, 2010 | 08:50 PM
daredevil95
I agree.....A friend of mine has a dyno. Thanks
