5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Coyote Aluminator Version
Old Oct 9, 2011 | 11:58 AM
JIM5.0's Avatar
JIM5.0
Default Coyote Aluminator Version
I just about S*** my pants while surfing through the net. I am damn surprised that I never saw this before. I am sure behind the times.
But I came across a Coyote that is supercharger ready and built with a long block to take it!
http://www.americanmuscle.com/frpp-a...na-1112gt.html
http://www.cjponyparts.com/product.a...paign=shopping
http://www.latemodelrestoration.com/...k-Supercharged
http://www.race-mart.com/Ford_Racing...007-A50SC.html
Sure this thing costs about s grand more than the 4.6L Aluminator, but since the Coyote block was designed to take FI from the very beginning, I feel more confident in supercharging that over the 4.6L
Old Oct 9, 2011 | 12:34 PM
stealth_GT's Avatar
stealth_GT
Wow.. that thing is gonna be scary fast one hooked up with boost!
Old Oct 9, 2011 | 01:03 PM
Templar's Avatar
Templar
Nice! Anyone using one of these with a S/C? I'd love to hear some results.
Old Oct 9, 2011 | 09:39 PM
dominant1's Avatar
dominant1
Nice find it must weight 100lbs less then stock!
Old Oct 10, 2011 | 09:49 AM
cjs06's Avatar
cjs06
Nice, it's got the 9.5:1 compression pistons. I'd imagine this could put out stupid numbers over a 4.6L aluminator.
Old Oct 10, 2011 | 10:17 AM
JIM5.0's Avatar
JIM5.0
And then some. With the lowering of the static geometric compression ratio, that allows for the much higher pressures from the dynamic compression ratio of double digit boosts.
With an all true forged lower end, I am sure guys will be pumping above 20PSI manifold into this thing to get some seriously sick outputs.
The next obstacle: putting all that power onto the track in that all desired perfect tire hook-up!
Old Oct 10, 2011 | 03:39 PM
Mishri's Avatar
Mishri
Mish-ogynist
It isn't lighter than the stock block, our stock blocks are already alluminium, they were on the 05-10's too. the alluminator block has forged internals to handle more boost/higher revs. it's not about weight savings.
Old Oct 11, 2011 | 10:28 PM
JIM5.0's Avatar
JIM5.0
True that. True forged machined (or milled) H-beams are heavier, especially if they are steel. Alum forgings are lighter but they are also weaker unless you use alot more material.
And the fake forged (AKA sintered) are even lighter because they used pressed metal alloys (sinter forging 100% steel requires much more extreme pressures so as to be prohibitively expensive, so metal alloys which are weaker than steel are used).
Using steel machined H-beam true forged conrods do add more weight to the engine, but the weight is really not felt at curb weight, that weight is felt due to its rotating mass (moments of inertia). And since conrods not only rotate, but also move linearly (i.e. up and down with the piston), they also exhibit liner inertia as well.
The linear inertia and moments of inertia are felt more when you are accelrating the engine RPMs.
cr620
Oct 3, 2022 10:18 PM
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
fastbackford351
Oct 1, 2015 12:24 PM
