5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
Cams
Old May 14, 2012 | 01:19 PM
D00m3dHitm4n's Avatar
D00m3dHitm4n
Default Cams
Thinking about getting cams for my car. but i have no idea where to start, and was curious what you guys would suggest. Ill be staying N/A for a few years and will be sticking with just the basic bolt ons and eventually building up the internals over the next few years to prepare for the eventual F/I.
Old May 14, 2012 | 01:26 PM
S197GT07's Avatar
S197GT07
You have a 2012, with twin variable cam timing capabilities.
Find a better way to spend (read: waste)$1500, the gains are not worth it!
Old May 14, 2012 | 02:36 PM
D00m3dHitm4n
Ok, but if you were going to get cams for you car. Which ones would you get and why?
Old May 14, 2012 | 02:52 PM
S197GT07's Avatar
S197GT07
Well since I have a 3v my opinion is kind of useless.
The 4v's don't have many options at this point. You're pretty much stuck with either comp, the Boss Cams, or a "custom" set from JPC or L&M.
With the 4v there are 3458347345 other things I would buy before cams man.
Old May 14, 2012 | 04:28 PM
scottmach's Avatar
scottmach
Cams would be the absolute last thing I would do. And if you don't have the ability to install them yourself expect to spend at a minimum of $3,000-$3,500 with parts and labor. And that's probably being generous.
Old May 14, 2012 | 04:45 PM
S197GT07's Avatar
S197GT07
$1,500+ to install?
Good lord.
Old May 14, 2012 | 04:55 PM
Roush05's Avatar
Roush05
I know a guy that will do a NSR cam install for $150. Granted, he's an outlier, but most places charge around $400 for an NSR install, not $1500.
I was referred to the guy that does a $150 install by a man with a nice setup who knows a good bit about cars himself, otherwise I would be skeptical.
Old May 14, 2012 | 05:25 PM
scottmach's Avatar
scottmach
Huh? On these new 5.0 4 valves? Yea a cam swap is easy on a 3v and wouldn't cost as much. On a 4v you really need to pull the motor. Remember there are 32 valve springs to also change.
Old May 14, 2012 | 05:26 PM
Roush05's Avatar
Roush05
I was referring to a 3v, but I was also referring to NSR cams. If you are talking about cams that require a valve spring change, yeah it does get expensive.
Old May 14, 2012 | 05:30 PM
scottmach's Avatar
scottmach
Well this is the 4v 5.0 section you know.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
