5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Installing boss 302 LCA's on 14 GT ..cause a brake problem
Old 03-30-2014, 07:49 PM
KevStangZona
KevStangZona's Avatar
Default Installing boss 302 LCA's on 14 GT ..cause a brake problem
I did the install yesterday upgrading to the Boss 302 LCA's from American Muscle. When I test drove it I smelled the passenger rear brake smoking I can hear it is definitely on. I did not remove the caliper when doing the install. I just used a screwdriver to get brake cable off and back on. It seems fine on the drivers side but not the passenger.
KevStangZona is offline
Old 03-31-2014, 08:46 AM
BrazenStang
BrazenStang's Avatar
You probably didn't put the cable back on correctly. The end piece of the cable needs to be turned and sit flush into the little cradle on the caliper. Also, make sure that the cable sheath is installed correctly with the clip. Basically, if a piece(s) of the cable and sheath are not installed correctly it will pull on the manual brake which is the same as applying the e-brake inside the car. It should be easy enough to uninstall and re-install correctly.
BrazenStang is offline
Old 03-31-2014, 09:28 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
^ This is exactly what I was thinking. I would recommend popping the wheel back off and going over the installation again. You may find something very simple as the fix!
Hope this helps. Let us know if that doesn't work. Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
-Dan
AMDanBailer is offline
Old 03-31-2014, 12:20 PM
Sleeper_GT
Sleeper_GT's Avatar
Agree completely....Check that out first while you grease up the LCAs and before you pull the caliper off.
Sleeper_GT is offline
Old 03-31-2014, 12:34 PM
dcarlinf1
dcarlinf1's Avatar
Maybe the parking brake is stuck on that caliper?
dcarlinf1 is offline
Old 03-31-2014, 03:04 PM
KevStangZona
thanks I will look again tonight. I did not drive it today. Here is a picture of the emergency brake linkage if I can get it to work. Operator error on the forum. Just can't seem to get images here from google photos
I just asked my IT person and he helped me out. Here is the linkage as it is now.
Old 03-31-2014, 03:05 PM
KevStangZona
now underneath at the lca I think it is just hanging
Old 03-31-2014, 03:20 PM
KevStangZona
I will post a picture of the linkage at the lca
Old 03-31-2014, 03:23 PM
KevStangZona
got it using imgur to uplaod pictures.
here it is a the lca
Old 03-31-2014, 03:26 PM
KevStangZona
is the metal tab supposed to be in the clip at the lca and frame? I don't think it has the length. I did take pictures before I messed with it too I will have to look at them.
thanks again
Kevin
Quick Reply: Installing boss 302 LCA's on 14 GT ..cause a brake problem
