5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Sponsored by:
Sponsored by:
CAI QUESTION
Old Dec 24, 2014 | 10:18 PM
Breaux5.0's Avatar
Breaux5.0
Default CAI QUESTION
So I just got the steeda CAI for my 2012 gt. Instructions say that installing the intake without a tune can cause searious damage to the engine. So my ? Is I guess is that really accurate? If it were u guys would u install it without the tune r wait until u got a tune for it?
Old Dec 24, 2014 | 11:06 PM
iMuf's Avatar
iMuf
There is a reason they say that. Yes installing a CAI that requires a tune, without a tune, car harm your engine. Wait till you have a tuner and then install them both at the same time.
Old Dec 25, 2014 | 06:01 AM
scottmach's Avatar
scottmach
Yep, that CAI requires a tune. Do not run it without one. And honestly the stock CAI works better than the Steeda one.
Old Dec 25, 2014 | 07:03 AM
CMcNam's Avatar
CMcNam
Like the other two said...don't use it without a tune.
Old Dec 25, 2014 | 08:56 PM
cruisin5268d's Avatar
cruisin5268d
+1
Tune it, or return it and stick with the stock CAI that works just as well.
Old Feb 5, 2015 | 03:26 PM
gplracerx's Avatar
gplracerx
You need a tune because the intake tube in the Steeda CAI is larger in diameter than the stock intake tube. Since you plug your original Mass Air Flow sensor, which is actually a flow velocity sensor, into the larger tube, the same air velocity will result in higher air flow. The ECU doesn't know this unless it's reprogrammed (tuned) and it will make the mixture too lean as a result.
The FRPP Pro-Cal tune should give you the same increase in low rpm performance as an aftermarket CAI and tune, so unless you really need a few extra horsepower at high rpm, I'd go with the Pro-Cal tune for just driving around. It does require a minimum of 91 octane fuel, though.
Old Feb 6, 2015 | 04:23 AM
spectreman's Avatar
spectreman
Be prepared for a lot more intake noise too w/the Steeda CAI. I was really surprised how much more noise was generated w/the open CAI intake honk. Ain't a bad thing but it is louder than stock.
And yes, get the Steeda tune to go along w/it first. I'm running a Steeda 91 tune and it works really well in concert w/the CAI.
Lastly, the Ford engineers strongly recommended a oil catch can install also to help prevent any oil blow-by or misting, which can cause issues w/lowering of octane values, resulting in pre-detonation. I had all 3 items- the CAI, Steeda tune and catch can ( as well as a set of GT500 mufflers) installed simultaneously and haven't had an issue- it all works great together.
Steeda rules!
Lee
mapitts
May 15, 2016 02:57 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
firecoyote
Sep 27, 2015 02:37 PM
Ipaman
Sep 22, 2015 07:01 AM
