what size subs?
Old Mar 16, 2006 | 02:08 AM
movalstang's Avatar
movalstang
Default what size subs?
I HAVE A 02 GT AND IM PUTTING IN SOME SUBS IN THE TRUNK IM THINKING OF ONE 12 BUT SOME FRIENDS TOLD ME I SHOULD PUT ONE 15 IS IT POSSIBLE TO FIT IT IN THE TRUNK WITH AMP. OR SHOULD I JUT GO WITH TWO TENS OR SOMETHING.
Old Mar 16, 2006 | 02:23 AM
Bigmack6933's Avatar
Bigmack6933
Default RE: what size subs?
I seen a 03GT today with 6 12s in the trunk, its all in how you INSTALL... INSTALL is key, you can take entry level equiptment and knock people out with it.....
Old Mar 16, 2006 | 02:32 AM
Jimmz's Avatar
Jimmz
Yea it is, depends on what type of music you listen to and wat subs you get, I got 2 12"s and I love em, id suggest 2 12's over a 15"
Old Mar 16, 2006 | 03:20 AM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
What type of music do you listen to? What size enclosure could you put in the trunk? How oud do you want too get? Are you looking for spl or sq?
Old Mar 16, 2006 | 05:59 AM
blackout's Avatar
blackout
ORIGINAL: Hisss04Cobra
Sounds good.
Old Mar 16, 2006 | 11:28 AM
1fastzook's Avatar
1fastzook
It depends what amp your running too. what brand,wattage?
Old Mar 16, 2006 | 01:26 PM
Melectrok's Avatar
Melectrok
The biggest diffrence in size of subs is what frequency response do you want. The size of the sub will resinate at a certain frequency with less effor then other sizes. There is no rule for what size for the music, because each brand uses diffrent materials. The best thing to do is dermine your listening style. Figure out what frequence range you want, then check the specks on the brand of subs you want and see what the base frequency of each cone is. Alot of times this is listed so a rule is see what they are rated for and figure about in the middle. Changeing between a sealed or ported box will change the resonation frequency a great deal based on air space. 15's are mostly real slow deep bass, alot of which is below human hearing. 12's are typical low frequency bass like for base drum type frequencys, 10's will be more for snare drum type frequencys. The amount of subs you want depends on what spl you want. The two things that determine spl are stroke of the sub in and out, and the surface area of the woofer cone. Since you cant change the stroke, (well you can with the amount of power you give it), the easiest way to increase Sound Pressure Level is to add more subs.
Old Mar 16, 2006 | 05:27 PM
Hisss04Cobra
says hiththth
Adding more sub's doesn't increase spl....ever see when the "bronco boom" truck has a load of 12's in it and only managed like 163-164?
Old Mar 16, 2006 | 05:46 PM
1fastzook's Avatar
1fastzook
just get one of these and call it a day i might know where you can get one for cheap
[IMG]local://upfiles/29615/1503ED8FCF8A40929BB41828C3F59DB1.jpg[/IMG]
Old Mar 16, 2006 | 05:48 PM
1fastzook's Avatar
1fastzook
check out this set up
[IMG]local://upfiles/29615/74FB330F86C044FAA31467A1BCBA5476.jpg[/IMG]
