Dynomat
Old Feb 25, 2004 | 01:27 PM
EJD05GT's Avatar
EJD05GT
Default Dynomat
Anyone dynomat their trunk? Recommend it? I have an 03 Cobra and would have to stick the sub in the back.
-E
Old Feb 26, 2004 | 07:29 PM
Jimmz's Avatar
Jimmz
Default RE: Dynomat
I have it, it helps a little but you have to put alot on to actually make it work and its expensive, but since you got a cobra you prob can afford it.
Old Feb 26, 2004 | 08:31 PM
Choppa's Avatar
Choppa
Default RE: Dynomat
to make it sound rally good you would have to dyunomat the whole car bout 800 bux then you would tell the difference jus doing the trunk wont be worth it no matter how much money you have
Old Mar 5, 2004 | 06:09 PM
souron's Avatar
souron
Default RE: Dynomat
dynomat will help if you just do the trunk some of your other panels will rattle but if you do your trunk it will help your sound quality and will eliminate most if not all of your trunk rattle wich is what rattles the most
Old Mar 5, 2004 | 10:15 PM
CrazyCarAudio's Avatar
CrazyCarAudio
Default RE: Dynomat
I've done my whole Mustang up with Dynomat and it really does make a difference if your serious about your system. I'm a car audio installer and competitor. What I found to be the best places for it are to line the trunk, a small piece directly behind the licence plate ( or pick up the Dynamat kit for that), and cut two small pieces to put between the spoiler and the trunk hatch (physically remove the spoiler, cut a piece to match the size) this will take almost all rattling from the spoiler. If you want alot of Dynamat, go on Ebay, I've found extreme bulk packs for under $100 (tweeter sells it for $200+) I removed my back seats for a custom fiber glass box for 4 12's and two Kicker 1200.1 amps, so I need to have as many db's kept in the car as possible, Dynamat will help, the more the better.
Old Mar 7, 2004 | 01:09 AM
souron's Avatar
souron
Default RE: Dynomat
holy crap! what year do you have?
Old Mar 8, 2004 | 12:59 AM
tyybo's Avatar
tyybo
Default RE: Dynomat
I HIGHLY, recommend it, we are workin on a mitsubishi mirage and the truck in dynomatted and it sounds really really clean
Old Mar 18, 2004 | 06:59 PM
8750gt's Avatar
8750gt
Default RE: Dynomat
If you guys are serious about car installs, don't use dynomat. There's a lot of products on the market that are a lot better. If u spend about $1000, u can basically sound-proof your car. Go to a place that is serious car audio (i went to Audio Concepts Mobile in Calgary, AB) and ask someone there. I used a product called v-block. Tear everything out of your car and remove old sound-prood material. Clean all the metal and spray it with sound dampening(comes in a spray-paint can). Then you stick a light sound-proof sheet on all the metal parts (most important is floor of the car and car doors). Then a heavier pad goes on top of this, only on the floor. When i find the exact name of the product, i'll post it here.
Old Mar 28, 2004 | 10:52 PM
souron's Avatar
souron
Default RE: Dynomat
ok...my question has to be: why the floor of the car? alot of the sound deadening stuff such as dynomat is used to waigh down body panels and such so they dont flex, 'cause if they flex you lose db and it rattles, but the floor of your car doesnt really flex all that much so why would the floor be one of the more important place's? it doesnt make sense to me, so if someone would like to inlighten me? that would be great thanx
Old Mar 29, 2004 | 02:00 AM
D1g1tal V3n0m's Avatar
D1g1tal V3n0m
I ♥ Acer
Default RE: Dynomat
I would dynomat if you're NOT worried about weight. It will help but like said there are other alernatives out there. Spray in etc... If you want a cheap way to stop your license plate rattle (If it does rattle) is get some weather stripping for it and cut to fit etc. I'm not gonna go into too much detail but there is alot of other alternatives.
