Front Speakers for Shaker 500
Old Mar 21, 2006 | 05:39 PM
slowguy23's Avatar
slowguy23
Default Front Speakers for Shaker 500
Hey guys,
I just bought an '06 and it has the Shaker 500 in it. I want to replace the front speakers, so I have two questions. First, what would you guys recommend as a replacement? Also, does anyone have a .pdf file or a quick how-to on how to get the door paneling off?
Thanks!
Old Mar 21, 2006 | 07:50 PM
JJ_Stang's Avatar
JJ_Stang
Default RE: Front Speakers for Shaker 500
There are 9mm screws around the edge of the door and then there are 2 hidden torx screws 1 is behind the little panel where the door release is and then their is one behind the door pull, It's not hard at all just take your time, I put some MB Quart speakers in the door and they are so much better than the stock speakers.
Panel Removal PDF
Old Mar 21, 2006 | 08:10 PM
schmecky's Avatar
schmecky
jj is correct except they are 7 mm screws....or you can use 9/32 as well
very simple and straight forward as long as you get the hidden torx heads....
Old Mar 22, 2006 | 10:36 AM
Philostang's Avatar
Philostang
JJ, were those MBs conventional speakers or another plate system? If I'm not mistaken, the doors will accept a 6x8" speaker even though they come stock with a 4x6" plate set up. Yes/No?
Thanks,
-j
Old Mar 22, 2006 | 02:49 PM
schmecky's Avatar
schmecky
the speakers are enclosed 4" components made to fit in the ford 5x7 opening a standard speaker will bolt right in or you can make an adapter plate and add your own components
later
Old Mar 22, 2006 | 06:31 PM
JJ_Stang's Avatar
JJ_Stang
I made my own custom mounting plate to mount my component speakers.
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
mdg
Oct 1, 2015 07:04 AM
UrS4
Sep 30, 2015 10:13 AM
Sixer4Life
Sep 29, 2015 07:03 PM
