Componet Set Install
Old May 2, 2006 | 03:24 PM
Mr_Kebo's Avatar
Mr_Kebo
Default Componet Set Install
Check out the install
Componet Install
Old May 2, 2006 | 03:34 PM
seight311's Avatar
seight311
Default RE: Componet Set Install
Were you able to get your Mach tweeter grills back over your new tweeters?
Old May 2, 2006 | 03:40 PM
Mr_Kebo's Avatar
Mr_Kebo
Yes fits right back over them with no problems.
Old May 2, 2006 | 04:14 PM
laserred38's Avatar
laserred38
man looks really good....mmmm elemental designs....hey how do you take the door panel off? i can get the 2 panels for the window switches and door handle off..but then i dont know where to go from there
Old May 2, 2006 | 04:45 PM
Danbert's Avatar
Danbert
The hardest part of the door panel removal is remembering the plastic holder located at the front of the door where it is hard to see. Take that out and then push up and pull out on the door panel and off it goes.
Old May 2, 2006 | 11:13 PM
harrison's Avatar
harrison
Nice job!
Old May 3, 2006 | 12:54 AM
seight311's Avatar
seight311
Once the screws are out and you unplug the harness. Lift up and out.
Old May 3, 2006 | 01:01 AM
Mr_Kebo's Avatar
Mr_Kebo
Thanks guys. This is probally the easiest car audio install i have ever done.
Old May 3, 2006 | 06:06 AM
ttocs's Avatar
ttocs
havn't changed out the rear speakers yet huh? If it is anything like the 94-95 I am use to it is a pita...
Old May 3, 2006 | 04:23 PM
blk40th's Avatar
blk40th
hey i wanted to know did you amp those speakers. i was thinking about going with the bostons but the have the crossovers and stuff. so id need to gut the whole thing. i just wanted to know if id be able to get away with just the speakers. thanks
