popping sound from subs
Old May 8, 2006 | 12:18 AM
sl8anic's Avatar
sl8anic
Default popping sound from subs
Tried running an aftermarket HU with the Shaker 500 subs and speakers. Works well other than there's a popping sound when switching between modes (when subs get powered on). Anyone have an idea how to deal with this? Is an issue due to amps being powered after the HU?
AD
Old May 8, 2006 | 01:35 AM
laserred38's Avatar
laserred38
Default RE: popping sound from subs
ok if it pops between switching modes (sources you mean?...like from radio to CD?)...then it could just be amplifier noise...or interferrence from your power cable if they are too close to your RCAs...also could just be a lose connection on the amp or on the back of the radio
Old May 8, 2006 | 11:44 AM
JJ_Stang's Avatar
JJ_Stang
I think the problem is the head unit is sending 5 volts to the amps and the Shaker 500 amps are only expecting 1.2 volts. You will need a relay to step down the voltage.
Old May 8, 2006 | 01:15 PM
laserred38's Avatar
laserred38
OR could be that ^^
Old May 8, 2006 | 01:20 PM
sl8anic's Avatar
sl8anic
Hmmm... I better check the HU amp enable voltage, I'm not sure what the level is on there.
AD
ORIGINAL: JJ_Stang
Old May 8, 2006 | 01:59 PM
JJ_Stang's Avatar
JJ_Stang
Sorry I had the voltages wrong, Read this by Hawgman tells you everything that you need.
Old May 8, 2006 | 02:15 PM
sl8anic's Avatar
sl8anic
Awesome! Thanks so much!
AD
ORIGINAL: JJ_Stang
cr620
Oct 3, 2022 10:18 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
Sixer4Life
Sep 29, 2015 07:03 PM
MacSerio
Sep 27, 2015 01:05 PM
