Eclipse Navigation question
Old May 26, 2006 | 09:03 PM
brchan's Avatar
brchan
Default Eclipse Navigation question
Hi everyone,
I finally decided on buying the Eclipse navigation system, but I can't tell the difference between the AVN5435 and the AVN5500.
Does anyone know what the difference is? All I know is that the AVN5500 is the newest version. If there's no real difference, why would anyone pay $350 more?
Anyone have luck installing this yourselves?
Thanks!
Brchan
Old May 26, 2006 | 09:05 PM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Default RE: Eclipse Navigation question
ORIGINAL: brchan
Hi everyone,
Thanks!
Brchan
I have no idea about the eclipse models, but I would guess possibly graphics, and easier control functions...
Old May 27, 2006 | 08:39 PM
schmecky's Avatar
schmecky
as far as i know there really isn't any difference other then the new map that comes with the 5500 and the street map feature which basicly gives you general shapes of the buildings that are around you...otherwise as far as audio features go they are the same...
Old May 28, 2006 | 05:04 PM
brchan's Avatar
brchan
That's a cool feature. If that's true, maybe I'll spend a little more for it...
Thanks!
Old May 28, 2006 | 06:00 PM
austijc's Avatar
austijc
The main thing looks like the city view mode where it shows buildings. I've got the older one and it doesn't do that at all.
Old May 29, 2006 | 06:53 PM
schmecky's Avatar
schmecky
if you'd like check out www.eclipse-web.com
but be advised that the 05's do not have a VSS wire so a lot of the features do not work....i will check mine on the way home and see if it will pull it up properly without the VSS
i will let you know!
andy
Old May 29, 2006 | 09:24 PM
austijc's Avatar
austijc
You can tap the output shaft speed sensor at the PCM. You definitely want a speed wire going to the GPS so it can do dead reckoning when the GPS signal isn't available. If you search these forums, there's already a number of posts on how to find the right wire to tap. I didn't find it that hard of a job, but it did take some scraped knuckles to get the wire past the firewall.
Old May 30, 2006 | 12:06 AM
schmecky's Avatar
schmecky
someone should pass this info on to eclipse technical...
i guess i will have to do some research on it and hook up mine!
Old May 30, 2006 | 01:12 AM
laserred38's Avatar
laserred38
i'm not sure about the 5435...but straight from crutchfield's catalog:
the 5495 ($2399.99) has the internal 30 GB hard drive that rips your CDs and stores navi info
the 5500 ($1699.99) does not have a hard drive but it has dual slots...one for CDs and one for DVDs
the 5600 ($1999.99) which is new, does not have a hard drive either, but it has dual DVD slots so you can play a DVD at the same time as using the other DVD for navi
from the pics they show it looks like the 5500 and 5600 show the building shapes while the 5495 does not...again not sure about the 5435 though
Old May 30, 2006 | 03:20 PM
schmecky's Avatar
schmecky
ok...the 5500 does have the street map feature but it seems you need the VSS hooked for it to work right.....
i am gonna try and get mine hooked up in the next couple of days so i can tell you how well it works!
