12v line under dash?
Old May 28, 2006 | 05:11 PM
bsteen81's Avatar
bsteen81
Default 12v line under dash?
Can someone help me identify a 12v power line under the dash so I can splice into it? Thanks.
Old Jun 1, 2006 | 12:01 AM
jmmorgan82's Avatar
jmmorgan82
Default RE: 12v line under dash?
i dont know if you got an answer yet, but i hooked all my 12V accessories into the cigarette lighter power supply on the shifter bezel.
Old Jun 1, 2006 | 02:01 AM
IamtheChitt's Avatar
IamtheChitt
It either yellow or light green/purple on your ignition harness for constant power. Depending on what you are running, you may want to run it to the battery. If not remember to put a fuse when tapping on to the constant wire.
Old Jun 2, 2006 | 10:41 PM
qbuswell's Avatar
qbuswell
I would run a wire to the battery and fuse it properly. I have a 8 and 4 gauge wire running to my 1200w sterio for high current. I taped the 8 gauge wire and used another fuse for my accesories.
Old Jun 2, 2006 | 10:49 PM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: bsteen81
They have these things at almost any parts store called a "tappa fuse". It comes with a female connector and this thing that slips over one leg of the fuse.
You slip it over the fused side of the fuse (make sure for saftey!) and it sticks out above the fuse when it is in the fuseblock. You then plug the female connector onto the tappafuse (after you crimp the wire onto the connector).
I haven't found anything that is more slick or easier to use, and you don't have to cut into your stock wiring.
TCStangerv6
Oct 11, 2015 05:57 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
