I need help with putting an amp and sub in my 99 vert
Old Jun 2, 2006 | 05:50 PM
reddawg76567's Avatar
reddawg76567
Default I need help with putting an amp and sub in my 99 vert
I don't know what factory system I have(newb)... it's a two peace system....tape deck and cd player....but the cd is not a changer like everyone talks about with the mach 460...so don't know if that is the system I have. I think it has a front amp but can't find the rear ones. if it has them where would they be? I'm confused......what would be the best way to hook my 400 watt boss amp and my 10" RF punch.....HELP!!!!![:@]
Old Jun 2, 2006 | 07:42 PM
Rpvsurfer's Avatar
Rpvsurfer
Default RE: I need help with putting an amp and sub in my 99 vert
Ok mach 460 runs 3 amps, one in the headunit, runs all the mid/highs, and then two in the trunk that runs the 4 lows in the car, You will need to splice the wires in the back that are leading to the lows in the back, there is a mustang world article, google it, they tell you how to do it, but i recomend just getting a new headunit and just run the mid/highs, and the sub, i did that and it sounds pretty good.
Old Jun 2, 2006 | 10:31 PM
reddawg76567
I don't want to change out the unit for a few reasons but I don't know if this is a 460 is the thing...I cant locat the rear amps and I only have 4 speakers....2 doors and two in the rear side panal
Old Jun 3, 2006 | 04:11 AM
ttocs's Avatar
ttocs
the 460 is easy to tell if you have tweeters by the side mirrors and the rear speaker grills are different too. More then likely you don't have it as if you did you would know.
The easiest way to get a sub in a vert is to use the space for the spare tire.
Here is an example my shop did.
http://www.soundwerks.com/installs/g...ustang001.html
Old Jun 3, 2006 | 10:40 AM
reddawg76567
ty for the help...I think I'm going to get a line out converter.....hopefully that'll do the trick
Old Jun 3, 2006 | 02:50 PM
reddawg76567
ok I got it in but now it is not pushin like it should.....I've played with the gain and changed the wires around (thought maybe backwards) but just not hittin right.....maybe I should have a pro look at it
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Art161
Sep 9, 2015 10:33 AM
TimeLord101
Sep 4, 2015 09:27 AM
cbird1177711
Sep 3, 2015 08:43 PM
iamgobono
Sep 3, 2015 12:37 PM
