06 vert, running wire from battery question
Old Jun 4, 2006 | 08:15 PM
harrison's Avatar
harrison
Default 06 vert, running wire from battery question
I've looked and looked and don't see any convenient location for running the power wire to the trunk. Anybody with an o5 or 06 with a pic of where you ran the wire?
Old Jun 5, 2006 | 03:47 AM
Frank99ta's Avatar
Frank99ta
Default RE: 06 vert, running wire from battery question
What I did in mine was remove the battery and tray. Then, remove the panles on the passenger side interior. There is a large rubber grommet with some wires going through it. Place your wire through that grommet from the inside of the car. Once you remove the battery tray, you will see a ledge, reach around the edge and there is a small area underneath that ledge. That is where your wire comes out of the car. Once you get a grip on the wire, pull it tight so it doesn't touch the exhaust manifold and fit it under the battery tray, so it comes out on the positive side of the battery. I would also put some flex loom tubing over the wire just to make sure it doesn't get too hot or get cut by the ledge. Just make sure it's not gonna touch the exhaust manifolds and you're good to go.. Then put the battery tray and battery back in and you're done... Hope that helps..
importsmasher
Oct 9, 2015 04:42 PM
bond007
Aug 26, 2015 11:36 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
jjwinel78
Aug 17, 2015 03:34 PM
lrogers0613
Aug 6, 2015 10:51 PM
