hyperground cables
Old Jul 5, 2006 | 02:31 AM
silversol81's Avatar
silversol81
Default hyperground cables
does anybody know how to install hyperground cables?
Old Jul 5, 2006 | 02:09 PM
ttocs's Avatar
ttocs
Default RE: hyperground cables
I have been installing for over 10yrs and have no idea what you are talking about?? If it is just a brand of cable then there is no difference in the install. If it is some "special" ground cable then I think you are dealing with some snake oil......
Old Jul 5, 2006 | 03:29 PM
silversol81
they are bigger ground wires to replace smaller stock ones? my buddy had some on his car and they did make lights brighter and things work smoother.
Old Jul 5, 2006 | 03:51 PM
1fastzook's Avatar
1fastzook
i have no idea either?Have any links or pics?
Old Jul 5, 2006 | 04:01 PM
silversol81
you can find these things all over ebay. just type in hyperground wires or cables
Old Jul 5, 2006 | 04:47 PM
1fastzook's Avatar
1fastzook
oh its just some audio power wire.extra grounds will help in some cases like grounding the alt to the body/frame and motor,motor to body/frame ..ect.It will probally be cheaper if you just go to your local car audio store and buy some wire/rings and make them yourself
Old Jul 5, 2006 | 04:55 PM
silversol81
already have the cables. just need to know exactly how to hook them up.
Old Jul 5, 2006 | 06:21 PM
ttocs's Avatar
ttocs
this what you mean?
http://cgi.ebay.com/ebaymotors/Mitsu...spagenameZWD1V
for that price I see why they are called HYP-erground cables!!!!!!!!
Unless these are made out of PURE gold I don't see how they justify the price.
From what I gather these are just pre-made way of doing a big-3 upgrade? There should be one to go from the neg of the battery to the chassis, as well as a set + and - from the battery to the alt. This is always a good idea if you have a high power system as most stock ground use 8 awg, as well as 8 awg from the battery to alt. If you run a 4 awg cable for pwr and ground, and the stock ground is only 8 awg, you are limiting your system.....
Old Jul 5, 2006 | 07:39 PM
silversol81
yeah that's it. you can just go to any car audio store and pick up bigger ground wires. like $5. it really does help make everything run smoother. i've had them lying around forever and just want to get them hooked up.
Old Jul 6, 2006 | 12:44 AM
Jimmz's Avatar
Jimmz
What about battery cables? I saw a couple cars that replaced their stock battery cables with 1 or 4 gauge wire with the aftermarket terminals an everything does that make a big difference??? an wat is the largest gauge you can use?
