Rear Speaker Installation
Old Jul 25, 2006 | 12:22 AM
karmstrong_2's Avatar
karmstrong_2
Default Rear Speaker Installation
Hey guys, I'm thinking about replacing my rear speakers in my 98 GT with some Pioneer 4way 6X8's. I just need to know how to get to them. I have a convertible and am not sure if that makes a difference in how the panel has to come off or how I get to the speakers to switch them out. If someone could let me know I'd really appreciate it. Thanks
Old Jul 25, 2006 | 02:08 AM
1998gtcorpus's Avatar
1998gtcorpus
Default RE: Rear Speaker Installation
on a 98 connvertible be careful the panel does come off but its a tricky way to pull it...best bet is to remove the entire plastic panel back there to keep from breaking the clips by just removing the grill
Old Jul 25, 2006 | 11:01 AM
karmstrong_2
How do you get the entire panel off? Is it just snapped down by clips or is there any special trick to removing the whole piece? It will be much easier to work with if I take the whole thing off
Old Jul 25, 2006 | 11:42 AM
ttocs's Avatar
ttocs
you need to take out the bottom part of the back seat. there are two plastic pieces under the seat between where your legs would be. Push the center in and the seat will come out. there are a couple of screws under it.
Old Jul 25, 2006 | 12:43 PM
karmstrong_2
Then you can just pop off the panels from there once the screws are out?
Old Jul 25, 2006 | 01:33 PM
Stang562's Avatar
Stang562
When i changed the rear speakers, i first removed the door sill, then i just pull the panel from right behind the back seat, then it came right off since its held on by clips i believe, its not all that hard
Old Jul 25, 2006 | 01:36 PM
karmstrong_2
hmmm...would it be any different because it's a convt? I want to do this project quick and need it done before Friday for a show so any help is much appreciated
Old Jul 25, 2006 | 01:43 PM
Stang562's Avatar
Stang562
I have a convertable too
Old Jul 25, 2006 | 02:44 PM
karmstrong_2
Right on...perfect then...thanks a lot!
Old Jul 25, 2006 | 02:55 PM
dandragonrage's Avatar
dandragonrage
DO NOT use those 4/5-way pieces of crap. They are all marketing. More speakers is NOT a good thing in this case. Stick with 2-ways or component speakers, period. Even if you're sticking with Pioneer.
I wouldn't put 4-way speakers in my car even if I got them for free.
