tryin to hookup my speakers
Old Aug 20, 2006 | 08:02 PM
91mustangrunner's Avatar
91mustangrunner
Default tryin to hookup my speakers
ok i have a 92 mustang lx coupe. i bought it off a frined last week. he has the speakers in the dash, just stock i think. and i wired up the deck today. he had the speakers in the trunk. but i just put in a box with 2 speakers in the trunk off those wires for now. he also hooked up good speakers to the doors and ran wires to the trunk for an amp. i just dunno how i go about hookin up speakers to an amp. with the positive and negative for left and right side. and if i need a 2 channel or 4 channel amp. so if anyone could help that would be great. thanks.
Old Aug 22, 2006 | 02:04 AM
getafewlives's Avatar
getafewlives
Default RE: tryin to hookup my speakers
hmm ya idunno how to hook up the amp and sub, i havent had to do mine yet but i will have to.
Old Aug 24, 2006 | 10:03 PM
samseed101's Avatar
samseed101
ORIGINAL: 91mustangrunner
I can definately help you out with this, but first I need to know exactly what you are doing. Are you trying to hook up a sub to the amp in the back or is it just a set of 2-way or 3-ways? Also, how many speakers total are you trying to run off the amp?
Old Aug 24, 2006 | 11:53 PM
Mthd11's Avatar
Mthd11
your going to need amp wiring kits, speaker, and sub wiring kits. if you have those than nvm. It should be pretty straight forward.
Old Aug 25, 2006 | 05:11 PM
straitwangin's Avatar
straitwangin
then number of channels determaine how many speakers you untimetly want to drive. this is not always the case. but 90% of the time it is.
ex. 4 channel amp - 4 speakers
How ever 2 channel amp and be BRIGED to drive 1 speaker or as many speakers as you want in uninison and long as the impendance is correct.
Old Aug 25, 2006 | 07:50 PM
91mustangrunner
well i got a 1200 watt amp. i woudl like to get 1 12 sub in the trunk. bein a 92 coupe theres not alot of room so i mite even do a 10 or 2. ill see. but i was planin on hookin the speakers to one chanel and sub or subs to the second. have the subs wired in a sequence. and speakers hooked up normaly. any thoughts?
Old Aug 26, 2006 | 01:11 AM
315|Stang's Avatar
315|Stang
do seperate amps..one for the speakers and one just for the amp. it will be easier to setup your highs and then your bass. but this is my opinion and how i have setup all my systems in my car and others cars.
Old Aug 26, 2006 | 02:19 PM
91mustangrunner
alrite. ill give that a go when i find a sub box to fit in that tiny space they call a trunk in the 92 coupe.
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Doogie65
Sep 6, 2015 02:55 PM
TimeLord101
Sep 4, 2015 09:27 AM
