Nee some help
Old Sep 18, 2006 | 12:00 PM
LilDerk86's Avatar
LilDerk86
Default Nee some help
I have a 1999 mustang Gt with the mach 460 sound system. I want to take out the stock casset player and the cd player and replace it with an Alpine head hunit i have. how would i wire this up in order for the setup to sound right?
Old Sep 18, 2006 | 02:31 PM
schaedj's Avatar
schaedj
Default RE: Nee some help
Buy the Metra Wiring Harness - 70-5511 and use the wires to make your connections. You will probably want to solder in a 1KOhm resistor to the Blue (Solid) wire to keep the amp from popping when you turn it on. Make Good Connections, tape it all up (Or use Heat Shrink tubing) and plug it in. Should be just fine.
Old Sep 18, 2006 | 02:39 PM
schaedj's Avatar
schaedj
If you are eliminating the CD Changer (You will probably have to), you will need a kit to fill the hole. I think Scosche makes one. FM2157B. Replacement pocket for Ford
Old Sep 19, 2006 | 12:22 AM
LilDerk86's Avatar
LilDerk86
will this wiring harness run all the speakers and subwoofers?
Old Sep 19, 2006 | 09:33 AM
schaedj's Avatar
schaedj
Mine did. Since the harness populates all of the pins in the connector, it has to be providing signal to all of the speakers.
Old Sep 19, 2006 | 10:01 AM
LilDerk86's Avatar
LilDerk86
i heard something about wiring up some rca jacks or something to the little black connector
Old Sep 19, 2006 | 11:09 AM
ttocs's Avatar
ttocs
page 2 of my signature shows how I did it on my 94. I made it a little harder then it had to be but this way allows me to control the factory subs with the variable sub output on the deck, and really sounds good to be honest.
Old Sep 19, 2006 | 08:17 PM
LilDerk86's Avatar
LilDerk86
thanx for everyone's help. i'll post the outcome and share my thoughts
Old Sep 19, 2006 | 10:23 PM
jay00f4's Avatar
jay00f4
www.bestkits.com They have a harness (BHA5511R)that hass RCA's on it instead of speaker level. When you run speaker level into the Mach 460 Amps it is usually to hot so you have very little control over the volume. If you go RCA it is a low level signal closer to what the Amps are designed to take.
Old Sep 20, 2006 | 11:37 AM
ttocs's Avatar
ttocs
I still needed a line driver to boost my rca signal up to where it sounded good.
