Mono Amp Wiring
Old Oct 6, 2006 | 01:04 AM
stanglx2002's Avatar
stanglx2002
Default Mono Amp Wiring
Can you wire 2 subs to a mono amp and if so how?
Old Oct 6, 2006 | 01:48 AM
86 5.0Lmustang's Avatar
86 5.0Lmustang
Default RE: Mono Amp Wiring
www.rockfordfosgate.com , check the site it has wiring diagrams
Old Oct 6, 2006 | 01:31 PM
ttocs's Avatar
ttocs
depends on the subs and the amp, but usually yes.....
watcha got?
Old Oct 6, 2006 | 01:33 PM
P Zero's Avatar
P Zero
Wire it in series.
-P.
Old Oct 20, 2006 | 07:09 PM
stanglx2002
ORIGINAL: P Zero
Wire it in series.
-P.
like this
Old Oct 20, 2006 | 07:14 PM
Derf00's Avatar
Derf00
Gentleman's Relish
All depends on the amps and subs you got. Are the subs 4 or 2ohm rated? Single or dual voice coil?
What can the sub handle for an ohm load? 1, 2, 4, ?
Need to know that before you just throw out a wiring diagram otherwise you can damage the speaker and/or the amp.
Old Oct 20, 2006 | 07:48 PM
ttocs's Avatar
ttocs
that would be parallel wiring that you show.....
how you wire it depends on what you have. Give us a list of the equipment and then we can answer this.
ORIGINAL: stanglx2002
ORIGINAL: P Zero
Wire it in series.
-P.
like this
Old Oct 21, 2006 | 10:26 AM
stanglx2002
I have 2 Sony P5 12' subs and im going to get a new amp for them. Im getting a SONY XM-D9001GTR mono amp
Old Oct 21, 2006 | 06:56 PM
ttocs's Avatar
ttocs
single or dual voice coil? What impedence are the coils?
Old Oct 21, 2006 | 09:29 PM
stanglx2002
Size 12 -inch
Impedance 4 ohms
Cone Material Polypropylene
Surround Material Rubber
Sealed Box Volume (cubic feet) 1.15
Ported Box Volume (cubic feet) 0.82
Port diameter (inches) 3
Port length (inches) 12
Free-Air No
Dual Voice Coil No
Sensitivity 89dB
Frequency Response 18 - 2k Hz
RMS Power Range (Watts) 90-380
Peak Power Handling (Watts) 1300
Please draw a diagram for me please
thanks
