subwoofer ohm question
Old Oct 31, 2006 | 07:26 PM
4popperstang91's Avatar
4popperstang91
Default subwoofer ohm question
I curently have three 10 in mtx blue thunders that came in a box from mtx that a friend had baught brand new, which are I think 8 years old and they are each 12 ohm and there each wired two the back of the box. the amp sees a 4 ohm load.
My question is I want to go down to two subs, then my amp will see a 8 ohm load and my amp will end up puting out alot less power then its suppose to, can i use a 12 ohm resister or higher so the amp will see a 4 ohm or 2 ohm load?
Old Oct 31, 2006 | 10:27 PM
ttocs's Avatar
ttocs
Default RE: subwoofer ohm question
if you went down to one sub you will have 6 ohms, not 8. Adding a resistor will not help you get any more power as the resistor will burn off that power in the form of heat. It would be like slappin a super charger on yer stang but leaving the parking brake on....
Old Nov 1, 2006 | 12:05 AM
4popperstang91
would this be ok. run two of my subs at 6 ohm on a amp thats rated at 400 watts at 4 ohms. I think I read that the sound quality would go up if I did this. not too sure if im right.
Old Nov 1, 2006 | 11:54 AM
Hawk's Avatar
Hawk
You can run subs of a higher impedance on the amp. In your case you can run the 6 ohm subs (assuming they are 6ohms each) wired in series to give you a 12 ohm load (assuming you are only running 2). This is fine for your 4 ohm amp. You just wouldn't want to drop below a 4 ohm load because it could cause the amp to burn up.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
