Should I go with an 8 or a 10?
Old Nov 30, 2006 | 07:55 PM
Frostbitten's Avatar
Frostbitten
Default Should I go with an 8 or a 10?
Im looking to add one subwoofer. Just one and i need it in a small box. The amp I am going to use will be the JL 500/5 . It pushes 250watts rms to the sub channel. I need the single best sub that will run well off of 250watts. I was thinking about the JL 8W7, but the box is rather large and the audio guy at a local shop said that it would need more than 250watts.
Old Nov 30, 2006 | 08:13 PM
mustangman02232's Avatar
mustangman02232
Default RE: Should I go with an 8 or a 10?
thats a tiny amp, your not gonna get much out of it,
http://www.cardiscountstereos.com/Subwoofers.asp
Old Nov 30, 2006 | 11:06 PM
Frostbitten
but I dont want a big heavy sub. I do want loud bass though and a single amp so everything is lighter and cleaner. Any 5 channel amps that will push a sub hard?
Old Dec 1, 2006 | 02:44 PM
Stang562's Avatar
Stang562
that amp is most like going to be best used with your door speakers, if you want good bass you need something a lot bigger.
