Mach 460 Delemma
Old Dec 8, 2006 | 10:29 PM
CarlessAndy's Avatar
CarlessAndy
Default Mach 460 Delemma
I have a blown lower door speaker. So without reading too much into the details i went ahead and bought replacment speakers for the doors in my 96 convertible. I ended up buying polk speakers but the problem is that they are 4 ohms vs the 2 ohms that the system is set up to run on. The polk's are 5x7's (i know not the right size) but i can mount them with a little work. That isnt the problem. Im now debating on weather to just replace the one blown speaker in the door with a factory piece. I need peoples opinions on this. Im also setting up a subwoofer combo so that i dont blow any more speakers. What should i do?
Cliff notes -
Blown lower door speaker, bought polks wondering if i should replace with a stock piece instead of the polks because of ohm difference
Thanks,
Andy
Old Dec 9, 2006 | 03:31 AM
ttocs's Avatar
ttocs
Default RE: Mach 460 Delemma
do you still have the factory deck in the car?
Old Dec 9, 2006 | 02:50 PM
CarlessAndy
No, I have a panasonic head unit in it.
Old Dec 9, 2006 | 03:01 PM
86GreenMachine's Avatar
86GreenMachine
you can always play with the ohms you know
Old Dec 9, 2006 | 03:03 PM
CarlessAndy
Im a noob when it comes to electronics so i would have no idea where to start.
Old Dec 9, 2006 | 03:04 PM
86GreenMachine
are your speakers running of the head unit or amps
Old Dec 9, 2006 | 03:05 PM
CarlessAndy
Everything at the moment is running off of the stock system through the stock amps. I have the polk speakers and sub/amp still sitting in their factory boxes.
Old Dec 9, 2006 | 03:12 PM
86GreenMachine
if both of your speakers you bought r 4 ohms u can wire them in together off the same channel that will drop the ohms down to 2 ohms or get rid of the stock setup and go after market in my stang of my speakers and componets are run of a concept 4 channel amp that way u can set the frequency of the speakers u can put as muc or as little bass through them so u dont blow them
Old Dec 9, 2006 | 03:13 PM
86GreenMachine
Old Dec 9, 2006 | 03:14 PM
86GreenMachine
[8D]
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
