need help with an amp...having problems
Old Dec 15, 2006 | 04:27 PM
PennState's Avatar
PennState
Default need help with an amp...having problems
hey im having problems with my amp..it wont power up any more...and the fuse is ok...
it just wont power up
what do u guys think the problem is??
Old Dec 15, 2006 | 05:14 PM
Hawk's Avatar
Hawk
Default RE: need help with an amp...having problems
Did you check the remote and ground? A test light will be your best friend here. Make sure you have all three connections and that they are good. The remote should only power on when the deck is on, so don't forget to turn your radio on when testing that connection.
Also, I would check and make sure that the battery terminal where the amp connects isn't badly corroded. If it is any of the above you might get lucky and a good cleaning with a wire brush is all you will need to do to fix the problem.
Old Dec 15, 2006 | 07:00 PM
PennState's Avatar
PennState
tried all of that...when i put the ground wire in to the amp...and then tried to put the remote wire..it sparked..also if i touched the remote wire any where on the plastic of the amp it would spark..i really cant figure out the problem.......
Old Dec 16, 2006 | 01:04 PM
PennState's Avatar
PennState
bump!
Old Dec 16, 2006 | 08:12 PM
ttocs's Avatar
ttocs
STOP TOUCHING STUFFF.......... You probably need to replace the fise in the radio for the remote turn on to start. The sparks you saw should have lasted a second or two while you GROUNDED THE REMOTE TURN ON TO THE AMP CHASSIS........ For future reference, that is bad and you should not do it. We need ya to get out a volt meter or test light and then we can get you through this, if you don't have one you can get one for a few bucks at an auto parts store. You need to check the power connections at the amp with the radio on and off.
Old Dec 16, 2006 | 11:26 PM
Sebski's Avatar
Sebski
alright... before you try and be master intaller... check the fuse.... if that is blown then that is ur prollem... if not... then try and gettin a wire and connect the ground to the remote... if that doesnt power up the amp.... ur amp is no good
Old Dec 17, 2006 | 12:27 AM
PennState's Avatar
PennState
ORIGINAL: Sebski
fuse is good!!
and what does it mean to get a wire and connect the ground to the remote..sorry im just really stupid with this stuff!
Old Dec 17, 2006 | 11:16 PM
PennState's Avatar
PennState
please help?
Old Dec 17, 2006 | 11:45 PM
silver2006's Avatar
silver2006
1ST of all don't touch ground to remore. the amp has 3 power connection. power, ground and remote. you said fuses are good. power is an always on 12volts from the battery, ground is any body part of car. the remote is a 12volt switched on with key/radio. if you been touching remote or power to ground or the amp itself check fuses again. if good, take a piece of wire and touch it from power on the amp to remote on the amp. what this is doing is giving the amp the turn on voltage it needs. if the power light doesn't come on then. remove the amp from the car and use jumper cables from the battery + to power, - to ground and a piece of wire from power to remote. if it doesn't work then you need new amp or to get this one fixxed
Old Dec 17, 2006 | 11:50 PM
silver2006's Avatar
silver2006
oh yea if the amp powers up on the 1st try. the remote turn on from the radio is must likely bad. if it turns on with the 2nd try check all wires. you will need a volt meter or test light for that.
