CD player install "what do the wires do?"
Old Jan 2, 2007 | 01:57 AM
sleeper_inc's Avatar
sleeper_inc
Default CD player install "what do the wires do?"
Sorry to double post this but in the 2.3 section their help is well intentioned but SLOW. Does anyone have the wire diagram for the stock (not premo) stereo on a 1988 mustang? like what all the wires do... Any help is great as I am starting to run out of time to do this project.
Old Jan 2, 2007 | 03:46 PM
stangcrazy's Avatar
stangcrazy
Default RE: CD player install "what do the wires do?"
Hopefully you havn't cut off the factory harness. You can purchase a new wireing harness (from Best buy,circuit city, even wal-mart) that will clip into your stock harness and it will give you labled cable to install a new stereo with.
Old Jan 2, 2007 | 04:00 PM
ttocs's Avatar
ttocs
there are a couple of different wiring systems that could be in there. Under the radio, is there a metal box that is octagonally shapped and has a bunch of holes in it? if so that is the amp for the premium sound system, if not then you have the standard. Once we establish this I can give you the color codes I have but you will still need to test them before you wire them up and turn it on.
Old Jan 2, 2007 | 04:18 PM
sleeper_inc
I do not have ther premo (has it says in my post) and the factory harness can be fixed, but I wouls rather wire it wire to wire.
Old Jan 2, 2007 | 06:59 PM
sleeper_inc
Ok I got it installed now I got another problem. When I start the car the memory of the CD player is whiped, clock, settings, everything is rest, it is wired right and now I am a bit confused and I want to just throw the car in the lake, but I wont because I need the car. So... Any ideas on what I have to do to fix this issue?
Old Jan 3, 2007 | 07:19 AM
stangcrazy's Avatar
stangcrazy
Ok you have it hooked up wrong then. I am guessing you have a Multi-meter or some other way to check for power. Basically you donot have your 12volt supply hooked up correctly. It keepspower on your headunit so your settings donot get wiped everytime you turn it off. Basicaly from your cars old wiring system all you need is the Power(12V), Ignition, Ground, and speaker cables.
Find your ground, I usually just do a continuity check from all wires toa chassis ground. Connect that to new harness.
Make sure the car ignition is turned off and use which ever power checking device you have to look for your 12volts. That will hook to your power.
Then your going to want to find your ignition wire. Turn your key to the position just before starting your car then take your power checking device and look for another wire with 12 volts. After you fins this connect it to your ignition wire comming from the new unit.
Then unless you have a power ant or your hooking up an amp the only thing you have left to do is trace out your speaker wires.
When your making these connections you should be using atleast some crimping barrelsor soldering. What ever you do you don't wanna just twist them together and use electrical tape.
Old Jan 3, 2007 | 10:24 PM
sleeper_inc
Yeah... to late on the twist thing, but what ever. I am going to re-connect the old harness and use a kit to make it right, should have done it in the first place but hell I aint that smart![:@]
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
