Getting to the Speakers
I'm getting the winter beater ready. I need to replace my front factory speakers. I know how to get the door panel off but it is stuck on the window crank. Does anyone know how to get the window crank off? I heard something about a clip on the inside but I have no idea how to get to it. Thanks.
There is a retainer clip inbetween where the crank handle meets the door panel, either in front of or behind the round spacer. Just pry the crank handle and the door panel apart just enough to see the clip (don't pry them too far tho) and use a small screw driver or pair of pliers to pull the clip off the shaft. They make a special tool to do this, but it's not necessary. Once that's off, the crank handle should slide right off the shaft. Good luck..
breaking
Oct 2, 2015 01:27 PM
