Stereo Dosnt work
Old Jan 10, 2007 | 11:21 PM
clix813's Avatar
clix813
Default Stereo Dosnt work
All my power to the stereo is gone. I made sure there were no poped fuses that I could find. Is there any other fuses that I am missing I got the ones that are under the hood and the ones behind the head unit and the ones on the amps. Is there any other ones that I am missing that would just cut of the power only to the stereo all the other thing that use electricity work like windows lights ex. The amps are not even turning on is there some thing that i am missing here?
Old Jan 11, 2007 | 01:48 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: Stereo Dosnt work
Well, I see you are checking it out too......any ideas seight???
Old Jan 11, 2007 | 01:49 AM
Jazzer The Cat
Retired Moderator
Hit refresh, seight!
Old Jan 11, 2007 | 04:26 AM
ttocs's Avatar
ttocs
time to get out a test light or voltmeter and check power behind the radio. There are often fuses in the back of the radio as well if you did not look.
Old Jan 12, 2007 | 10:48 PM
clix813's Avatar
clix813
well im taking it to a place tommarrow so they should get it fixed. ill let you all know what caused this when im done
Old Jan 13, 2007 | 12:09 AM
PennState's Avatar
PennState
do your windows role down!
Old Jan 13, 2007 | 12:23 AM
clix813's Avatar
clix813
yeah everything else works it just the stereo im clue lessI checked all the fuses only thing that I can think of is either the wire that i have got fried, bad ground or my amps burntout.
Old Jan 13, 2007 | 10:28 AM
PennState's Avatar
PennState
yeah do u have subs or anything
cause my remote wire for my amp went bad
and it shut down the radio, windows and power mirrors.
Old Jan 13, 2007 | 03:05 PM
ttocs's Avatar
ttocs
I am guessin a shop didn't put that in?
ORIGINAL: yomofoitzjay
Old Jan 13, 2007 | 03:07 PM
ttocs's Avatar
ttocs
5 mins with a testlight behind the dash is all you would need to diagnose it. Test for power on the +12v switched(red) with the key on and off, as well as for voltage at the +12v constant(yellow). You need to determine which/if these two are dead. If they are not then your deck is probably the problem.
