Need help with sub/amp setup
Old Jan 23, 2007 | 10:58 PM
CarlessAndy's Avatar
CarlessAndy
Default Need help with sub/amp setup
Ive got a sub and amp setup and all the wires are run. The problem is that with the rca's connected to the amp stays at a constant low volume. Ive tried messing with the HU controls and they do nothing. When i connected the amp through speaker wire the volume control worked. Is there something im missing? Ive tested the amp, sub, and all other connections. I checked the wiring on the back of the HU also. Suggestions?
Old Jan 23, 2007 | 11:20 PM
ttocs's Avatar
ttocs
Default RE: Need help with sub/amp setup
need a list of what is in the car, and what you are putting in the car.
Old Jan 23, 2007 | 11:22 PM
CarlessAndy
The HU is a panasonic with xm hooked up. I am installing a sub/amp in the trunk in a box. Other than those items the rest of the system is stock mach 460 parts.
Old Jan 23, 2007 | 11:25 PM
CarlessAndy
Forgot to say that ive run the rca's, power, ground and amp turn on wires.
Old Jan 24, 2007 | 12:38 AM
PReal's Avatar
PReal
It sounds to me like your high pass filter might be on. Check all of the settings on the amp.
Old Jan 24, 2007 | 12:50 AM
CarlessAndy
That actually is the only thing i messed with on the amp controls itself. I tried to turn the bass up on the HU it self also to try and get some more sound out of it. There is also a "Bass EQ' **** and a "Gain" ****. Should i change these settings?
Old Jan 24, 2007 | 01:31 AM
billyam87's Avatar
billyam87
looking at the Amp controls and seeing the Bass Eq, that most likely means that this controls the low pass filter of the amplifier. If the measurement on this control are in Hz then that is what it is. The Gain control is going to determine how much the amplifier actually amplifies the signal. I am not sure of the amps or the subs. With the stereo on, turn the Bass Eq to about 120hz and then slowly start to turn up the gain. Also, some amplifiers have a switch to switch between low level inputs and speaker level imputs, with the RCAs you want to be on low level input.
Old Jan 24, 2007 | 01:46 AM
ttocs's Avatar
ttocs
Depending on the deck the rca's may be non-fading. The gain setting you mentioned is probably the volume for that output.
Old Jan 24, 2007 | 10:50 AM
PReal's Avatar
PReal
You should have to set the gain on the amp to match the output voltage on your hu.
Old Jan 24, 2007 | 11:52 AM
CarlessAndy
Ok, ill mess with the controls tonight and will let you guys know. Thanks for the help!
