Remote start PATS bypass
Old Feb 16, 2007 | 06:21 PM
02DKBLUE's Avatar
02DKBLUE
Default Remote start PATS bypass
I've just finished installing a 2-way remote start alarm system in my 02 GT. The remote start works, but i'm struggling with the PATS bypass module. I have one of the universal bypass kits... it has a wire that has to wrap around the ingnition cylinder several times (http://buypasskit.com/files/images/product144.jpg). I've experimented with several spots but i can't seem to find the right spot. Here is a picture of what i'm working with.
http://render2.snapfish.com/render2/.../of=50,590,442
Any help is appreciated.
Old Feb 16, 2007 | 09:57 PM
ttocs's Avatar
ttocs
Default RE: Remote start PATS bypass
those things are touchy to say the least. What I have found often is that the metal around the collar seems to block the signal and it is best to try and have the wire ring as far towards the key as possible. Most of the time I have to play with it for 30-60 mins holding it in place until I found the sweet spot, and then glue it in place with some quick drying CA glue with activator. Often it ends up inbetween the plastic piece that goes around the key, and the metal part of the collar.
there is not much security help on here other then me. Try carsound.com security forum but be warned there are alot bigger a-holes there then here........
Old Feb 17, 2007 | 02:27 PM
02DKBLUE's Avatar
02DKBLUE
thanks for the help ttocs, i guess i'll just have to keep messing with it.
Old Feb 18, 2007 | 11:37 AM
ttocs's Avatar
ttocs
wish I had more to tell you, they are picky little things you just have to play with... You can check to see if the module is working properly by hitting the remote start with the key in the ignition to see if it fires up.
Old Feb 19, 2007 | 09:53 PM
schmecky's Avatar
schmecky
did you do like he said and try it with the key in the ignition yet??
the pats arent' all that picky.....but again i'm used to using a 556U from DEI and have yet to have one not work on my first shot....but it helps that i install starters for a living and live in michigan
let us know what you find out!!! and i can try and help too....
Old Feb 20, 2007 | 08:07 PM
jgorm's Avatar
jgorm
You can also turn pats off in the tune.
Old Mar 3, 2007 | 07:59 PM
02DKBLUE's Avatar
02DKBLUE
Well i got it to start, tighented the wire up as much as possible and put everything back together and then as soon as all the pieces were put back on the car it wouldn't work anymore. I took it all back apart again and no luck ever since. This thing is being a major PITA. I checked the bypass module and it is getting power right when it is supposed to, the key that is in it is good... I remote started it with the key in the ignitioin and it worked everytime. Im not sure whatelse to do. Possibly this bypass module doesn't put out a strong enough signal or something, here is the link to the one i bought(http://commandoalarms.com/itm100041.htm), i have a commando alarm/remote start/2-way system and everything works perfectly; it recommended that i buy this one so that is what i did. Any advice anyone?
Old Mar 3, 2007 | 11:30 PM
97tunedmustang's Avatar
97tunedmustang
Thats a weird bypass module ya got there. this is the one i purchased for my viper 791xv and it works great and does not require a key to be locked away either. All i did was stuff the little transmitter up into the column by the ignition lock and programmed it from the instructions provided and i haven't had a problem since.
http://cgi.ebay.com/NEW-DEI-555F-FOR...em260024242616
Old Mar 6, 2007 | 01:41 AM
jtstudley's Avatar
jtstudley
Quick question. I had my remote start installed, PATs bypass and all. I thought I would be able to buy a spare key with no chip and it would work. But its the same as if there were not bypass, how does it only bypass for the remote start? Sorry to kinda hjack but i noticed your problem was solved.
Old Mar 6, 2007 | 03:51 PM
02DKBLUE's Avatar
02DKBLUE
I know that the bypass module that i bought, it is only activated when the remote start is activated. The bypass module only has 2 wires, 12V constant and a ground; the ground is grounded through the remote start/alarm system. When my remote start is activated, it turns the bypass module on by grounding the wire that attaches to the bypass module (completing the circuit)... anyways, the bypass is only active when the car is running in remote start mode. As soon as you put the key in the ignition or touch the brake, the bypass turns off and the PATS system is reading from your actual key and no longer from the emulated key signal that the bypass produces... and this is why you still cannot use a key without a chip.
