Very strange amp. problem
Old Feb 17, 2007 | 03:55 AM
dollarbill689's Avatar
dollarbill689
Default Very strange amp. problem
Hey everyone. I have a 2003 mustang gt with the mach 460 sound system. I added an amp and 2 subs, using the line-out converter. Everything was working great for a couple weeks until a couple days ago a random sound started being produced. It only came out of the subs when the engine is on. Its not like a popping or anything, it sounds like a beat. The pitch and frequency of the beat is changed when i hit the brakes or use the power windows or turn my headlights on. Its not coming from my radio because if I take the rca inputs off of the amp the sound is still made. Also, if i have the windows up and i hold the button in the 'up' position it stops making the noise if i am at rest or braking. Also, having headlights on and the rear window defroster will stop the sound for a while. I changed where it was grounded, no luck. Ive also asked a couple of professional audio shops around but then want something like $60 an hour to even look at it. Any ideas?
Old Feb 17, 2007 | 12:12 PM
my77stang's Avatar
my77stang
Default RE: Very strange amp. problem
sounds like electrical noise. i knwo they make filters for stuff that doesnt use alot of juice ( like a head unit ) but i dunno if anything is available for something large like an amp.
Old Feb 17, 2007 | 03:14 PM
Maxwelhse's Avatar
Maxwelhse
Do you have your line level box/wiring anywhere near your power wires? Try moving the wiring around and see if the sound gets better or worse.
Those ground loop boxes have never worked for me. It's a nice idea, but the right way is always where the pay off is.
I've seen voltage regulators in the alternator go bad and create that condition too. You might want to run a good alt test and see if anything is abnormal.
Old Feb 18, 2007 | 11:35 AM
ttocs's Avatar
ttocs
that popping noise is normal in the mach systems as I have it in mine. It is annoying but doesn't hurt anything.
Somebody on here once said that putting a 1k resistor inline with the remote wire worked but that is bs, didn't help anything.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Emblazoned
Sep 3, 2015 10:45 PM
