What are the speaker wires in my car?
I am in the last part of installing my amp and sub, and am not sure which wires are the speaker wires for the left and right rear speakers to hook up the high level sensing wires. I see the amps and there are two plugs on each amp in the trunk. There is one plug in each amp that has three wires and then there is one plug with 6 wires going into it. Which of these wires is the positive/negative for each speaker? Thanks and i appreciate all of you that have helped me along the way!
or are all four in the 6 wire plug? i see two black wires with white stripes and 2 black wires with green stripes. are these the wires i am looking to use? Thanks!
I'm sorry there are 8 wires in each of two lpugs with one being black with a white stripe and 3 or four having a green stripe. I don't know where to hook my sensing line!!!
http://www.swaaggs.com/documents/aud...290b&d.pdf
http://www.swaaggs.com/documents/200...iagnostics.pdf
hope this helps, couldn't find much else
i am pretty sure i am supposed to be running off the two black and white wires but no idea about the black and green wires cause there are 6 or 8 of them. This is the last thing ineed to do and i can't find it anywhere. Are the two amps in the trunk for just the rears or for all the speakers?
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
