Never had this problem before
Old Oct 31, 2004 | 02:50 PM
SXGT's Avatar
SXGT
Default Never had this problem before
OK i have my subs and amp freshly hooked up in my new box. I have the radio on and the are working good now i turn up the volume a lil bit and out of no where HUMMMMMMM* the subs are maxing out so i turn the volume all the way off and they are still maxing out. whats doing this? also it happens when i close my trunk.
Old Oct 31, 2004 | 04:34 PM
ceyko's Avatar
ceyko
Default RE: Never had this problem before
I might be Cpt. Obvious, but have you checked for loose/crossed wires? Power, ground and speaker wires needs to be checked. Is it just coming from the sub?
Take care,
Ceyko
Old Oct 31, 2004 | 07:26 PM
SXGT's Avatar
SXGT
wires ontop of other wires eventho incased in plastic make a difference?
Old Oct 31, 2004 | 07:29 PM
ceyko's Avatar
ceyko
Na, that is fine if it is insulated by something already - what I am referring to is a possible little strand of wire that is not right or something.
It was simply a suggestion to make sure you checked for that sort of thing. Other then faulty equipment I have no other ideas. The reason I asked if it was just the sub, is then you can narrow it down to
The sub
The amp
or the outputs from the head unit.
Ceyko
Old Oct 31, 2004 | 07:31 PM
SXGT's Avatar
SXGT
i hooked up just one sub and it seemd to fix the problem. but even tho just one os hooked up they are both moving>??? maybe its cause my box is air tight.
Old Oct 31, 2004 | 07:39 PM
ceyko's Avatar
ceyko
that would be my guess. Could it be that they cross connected the subs in the box? I am not a guru on this stuff, so I am just throwing out ideas. Are you using a two channel amp and just hooking one channel to each sub? I'd hook each channel up one at a time to see if both channels are good. You've pretting much proven that your outputs are good. I would then hook a channel up to the other sub and see if the problem returns. If not and you hook both up and the problem is there, I'd take a hard look inside that box.
I know there are various ways to wire subs and amps, but I am not a guru. Maybe someone else on this board can provide more information on the ins and outs on that stuff. Cause if it comes down to how the amp/sub is wired, I will not be able to provide reliable information. I'm just trying to help you pinpoint where the problem is.
Take care,
Ceyko
Old Oct 31, 2004 | 07:52 PM
Acewelder99's Avatar
Acewelder99
what subs and amp did you use the amp my not be powerful enough to drive the subs!
SXGT's Avatar
SXGT
well each sub has 8 guage wire coming out of teh box in seperate holes. then i had to use small speaker wire to get it all the way to the amp, i DEFF have my pos and neg correct. but why is my subs maxing out when the volume is off? I belive thats the key to the problem.
Old Oct 31, 2004 | 08:07 PM
ceyko's Avatar
ceyko
Dunno man that is why you are going to have to troubleshoot and figure it out. There is not a whole lot there to troubleshoot. Ya got the head unit and amp that can be providing a signal to the subs. Your going to have to figure out which one it is that is causing the problem.
Does your headunit have another set of outputs you can try?
Ceyko
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
