Speaker problems
Old Nov 1, 2004 | 10:42 AM
goatman's Avatar
goatman
Default Speaker problems
I recently installed a pair of Infinity Kappa 572.5cf 5X7, 100w RMS, 300W peak on a JVC KD-LH300 deck. I am experiecing feedback (or cracking) at high volume. What causes this? How do I fix it?
Any help is appreciated.
Thanks,
Todd
Old Nov 1, 2004 | 10:44 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Speaker problems
you (had) got the mach 460 system?
Old Nov 1, 2004 | 08:26 PM
goatman's Avatar
goatman
No, I got the stock system, I was advised to stay away from the Mach.
Old Nov 1, 2004 | 10:43 PM
Acewelder99's Avatar
Acewelder99
start off checking simple things like all connections and make sure there are no bare wire anywhere. You may be putting to much power to the speakers and they would give cracking sound.
Old Nov 3, 2004 | 03:24 PM
stangcrazy's Avatar
stangcrazy
I agree with ACE look for loose ground connections and bare wire. For the popping try adjusing your bass a little lower at those higher volumes.
Old Nov 3, 2004 | 11:50 PM
Acewelder99
also check and make sure that nothing is touching the speaker because that could give you a cracking sound. Let us know how you made out!
Old Nov 10, 2004 | 10:42 PM
goatman's Avatar
goatman
Checked all the wires, no problems. I think is may be that the Infinity's can't handle the high volume so I'm going to install some pioneers....
Thanks for the help.
JoshyGT
Sep 19, 2017 08:52 PM
stangin1996gt
Sep 21, 2015 11:01 AM
unit91
Sep 15, 2015 09:53 AM
Doogie65
Sep 6, 2015 02:55 PM
TimeLord101
Sep 4, 2015 09:27 AM
